Crankshaft
Old Mar 16, 2006 | 07:29 AM
Chumbucket's Avatar
Chumbucket
Crankshaft
Can the machine shop turn crank and fit new bearing's without having the rod's ?? Main bearing's and rod bearing's.
Old Mar 16, 2006 | 04:40 PM
plowhand's Avatar
plowhand
Playing in the Dirt
They can turn your crank by itself. BUT.....to make sure everything matches up it is a good idea to make sure they have everything, so they can check for spun main bearings, wear in the main caps, center line bore, etc. . AND..... unless you have a custom crank, it is usually just as cheap to replace the crank with a new one, due to the major amount of labor (time wise) that goes into setting up and turning a crank. What ever machine shop you are going to use, just call them up and ask them any shop questions that you have most will answer you, the ones that don't, I would not do business with.
Daniel92f250
Dec 17, 2013 09:11 PM
Rmc292
Jul 10, 2013 10:26 PM
1978fordf250
Sep 3, 2006 06:42 PM
JJDDOOGG
Nov 27, 2002 12:18 PM
daydreamer
Jan 12, 2001 02:58 PM
