found a great website
Old Mar 28, 2009 | 05:53 PM
Franko72's Avatar
Franko72
Molon Labe
Came across this site while watching youtube videos, it is full of info on powerstrokes, and has lots of how-to maintenance videos.
I have been glued to it all day.....I cant believe how much i've learned.
Just thought I would pass it on.
www.powerstrokehelp.com
Old Mar 28, 2009 | 06:00 PM
ron's power stroke's Avatar
ron's power stroke
sorry to say..he isnt all that great....
Old Mar 28, 2009 | 06:26 PM
Ziggy.'s Avatar
Ziggy.
drain your hpop oil or else!!!!
But really though, he's done alot of work on the trucks, however has no clue whatsoever how most of it works/functions, and why. He is correct to a certian point on some stuff, but usually that point comes very quick in his videos, and goes downhill from there.
If you are interested in learning more about a 7.3, you would be much better off spending your time searching on here and doing alot of reading, and other places such as guzzle's or RHN.
Old Mar 28, 2009 | 06:46 PM
F350-6's Avatar
F350-6
If you're not familiar with anything under the hood of a 7.3, there is a lot you can learn from those videos. Just don't follow his advice blindly. Some of his videos are incomplete, inconsistent, misleading, of just plain wrong.
Old Mar 28, 2009 | 06:55 PM
guthrie&co's Avatar
guthrie&co
I saw this post first but I couldn't bring myself to down original poster since he is no new
Old Mar 28, 2009 | 06:58 PM
ron's power stroke
i do suck out my pump now and then after seeing that clip..but thats only cause my reservoir does not have a screen in it to help filter out the dirtier thicker stuff that settles to the bottom..
Old Mar 28, 2009 | 06:59 PM
F350-6's Avatar
F350-6
He's been a member since Dec 06
Old Mar 28, 2009 | 07:00 PM
guthrie&co's Avatar
guthrie&co
I checked out my pump for the first time at 236k. I had changed the oil recently and the oil in the pump looked just as clean as what was in the pan.
guthrie&co's Avatar
guthrie&co
I didn't look that far, I just looked at his post count
Old Mar 28, 2009 | 07:05 PM
MADVAN's Avatar
MADVAN
Bill
Old Mar 28, 2009 | 07:10 PM
Ziggy.'s Avatar
Ziggy.
^^^very well put
Originally Posted by MADVAN
Bill
Old Mar 28, 2009 | 07:15 PM
F350-6's Avatar
F350-6
I think all that does Ron is help change more of the old oil that doesn't come out when you pull the drain plug. Kris posted some pics a while back of the oil passage through the front cover (bottom half of the HPOP reservoir) and I don't see how you will accumulate anything in there aside from a thin film on the walls which changing the oil won't help.
Old Mar 28, 2009 | 07:26 PM
Ziggy.'s Avatar
Ziggy.
I could see someone doing it if they went from an dino to Syn and wanted to get all the dino out they could, I didnt bother doing it, but some might. Either that or if its a fresh engine rebuild and at that first oil change I would, just to get all the oil out I could that may have small metal particles in it from break-in. Short of that its pretty much pointless.
Old Mar 28, 2009 | 07:33 PM
ron's power stroke
I have been though 3 turbo's..a lot of aluminum, tin and what ever else gets into the oil when a turbo goes..some time its alot before you find out the wheel has been hitting.. that also ends up up top..now I just try to do it now and then for a piece of mind...i cant run down town to get a new injector
Old Mar 28, 2009 | 07:38 PM
F350-6's Avatar
F350-6
I have been though 3 turbo's..a lot of aluminum, tin and what ever else gets into the oil when a turbo goes.. that also ends up top..now I just try to do it now and then for a piece of mind...
Have you considered installing the screen Ron? Is your front cover shaped different where the screen won't fit? Where's your pic of the broken gasket in the reservoir? I believe the screen should fit yours.
