cab light specs
Old Mar 27, 2009 | 11:34 PM
twisted84toyota's Avatar
twisted84toyota
Question cab light specs
I want to add clearance lights to my truck is there and specific measurements out there I can take so I get the spacing correct.............or a template I'd like it to look like a stock job
Old Mar 27, 2009 | 11:44 PM
Bgasrickshaw's Avatar
Bgasrickshaw
I don't have a template but if nobody else answers you tonite I will go out and measure mine in the morning and post the measurements
Old Mar 27, 2009 | 11:45 PM
twisted84toyota
SWEET
thanks
John
Old Mar 28, 2009 | 02:11 AM
Jermafenser's Avatar
Jermafenser
There have been a few threads on measurements, including the factory measurements in the past.
Do a search on yellow-something. Yello-Mello?
Old Mar 28, 2009 | 02:58 AM
kshaneh's Avatar
kshaneh
not to be a thread jacker or anything lol, but what do you all think of the smoked/blacked cab lights for a new f250. they got 9 leds in each lite??
Old Mar 28, 2009 | 03:01 AM
Jermafenser
Sounds like a pile of ugly.
Old Mar 28, 2009 | 03:09 AM
kshaneh's Avatar
kshaneh
<a href="http://s162.photobucket.com/albums/t266/kshaneh/?action=view&current=img.jpg" target="_blank"><img src="http://i162.photobucket.com/albums/t266/kshaneh/img.jpg" border="0" alt="Photobucket"></a>
Old Mar 28, 2009 | 10:18 AM
twisted84toyota
man thoes things are nasty looking...............going for more of a STOCK style!!
Old Mar 28, 2009 | 10:51 AM
Bgasrickshaw
O.K. Just measured 2 of mine (a '77 and a '78) The first measurement is the distance back are from the middle of the curve above the windshield, that is to say where the roofline curves down a couple of inches above the windshield to the front edge of the lite base ,the frontmost point where the lite housing touches the cab. (hope that makes sense) This distance is 6 3/8 " Working outward from the middle,the side to side distance from the center of this lite to the center of the next one is 9 1/2" (same on the other side, of course) and the distance from the center of those lites to the center of the outboard lites is 15 1/2". They are layed out in a dead straight line, meaning they do NOT follow the curve of the roofline above the windshield. For the actual distance back from the curve above the windshield to the center of the middle hole, you need to add the distance from the front edge of whatever lites you are using to the point where the wire comes out. In my case, using factory lites it is 2 1/2', making the full distance of setback to the center hole 8 7/8", but I'm not sure if this varies year to year, somebody else may know. The hole diameter on mine is 9/16". So if you lay them out in a straight line using these numbers and make sure the two outside lites are the same distance back, you should be good to go. And even with gaskets, I would use some kind of sealer around the holes or they might leak. Silicone, plumbers putty, bear fat, whatever. Hope this helps.
Old Mar 29, 2009 | 11:03 AM
twisted84toyota
Sweet........thanks a ton!!
I have a friend that used to work at a semi trailer fab/repair shop and he has some putty sealer that never hardens but remains stiff they use it as a seam sealer,a light sealer,and an adheasive for refer trucks that should work out well for what I need best thing is the price........FREE.99
Old Mar 29, 2009 | 04:29 PM
73f100shortbed's Avatar
73f100shortbed
LOL I agree. The stock type would look better.
Old Mar 29, 2009 | 05:41 PM
Tees77f150's Avatar
Tees77f150
Thanks, this is an upcoming project I have and this helps me alot!
PS: Rep points for you!!
Old Jun 18, 2009 | 09:31 PM
Diesel_Brad's Avatar
Diesel_Brad
I have to do this on Josh's truck too. Also a Lund visor. Anyone have pics from above w a Lund visor and cab lights. Can i use the visor as a template. I did this on my 96 and it worked perfect.
Any sugestions on where to get a Lund visor cheap?
stuckstudent
30
Jun 2, 2023 07:36 PM
ssande
Jun 22, 2017 10:20 AM
JDJR59
Feb 20, 2017 11:51 AM
Rmblanchard02
Sep 8, 2016 03:38 PM
Doubleubar
Feb 24, 2016 06:33 AM
