I thought it was interesting that Sooper-Doodie pointed out that he misspelled a word, and misspelled it differently in his correction. Most people's hides are not THAT thin.
I know your tenure with Ford may have ended before the 6r140 program was in full swing, but you wouldn't happen to have any info on it would you?
LOL- if you only knew exactly how RIGHT you are! Mark IS "Mr. Transmission-know-it-all"!
Mark worked for Ford's powertrain division designing transmissions and has been helping Ford truck owners with questions/issues for over 12 years... at least that's how long I've known him (online).
Sorry Sooper-Doodie...but I think the online word for this is PWNED.
Don't bother with swapping ECUs. You can turn the auto trans functions off in the tune easily.
Then run the stand alone tranny controller for the upgraded tranny.
Win/win.
No chit?! WOW! I'd really rather have a 6-speed manual. Had no idea I could just turn off the tranny functions in the existing ECU. Reps!
Edit: Damn, I must be typing too fast....Didn't even see that I misspelled "Torqueshift" in the title.
And after Mark chimed in with the correct spelling, I fixed it for you.
Originally Posted by Mark Kovalsky
You misspelled it here, too. The right spelling is TorqShift.
Mark is right.
Originally Posted by Sooper-Doodie
Wow, good one Mr. Transmission-know-it-all. Glad you pointed that out. Sometimes I wonder why I continue to contribute to this site.
Moderators: Please delete this thread.
Mark IS Mr. Transmission-know-it-all, when it comes to the 4R100 and the TorqShift (5R110).
Originally Posted by Krewat
Title editted.
Need a tissue?
Like I said, I fixed it for you. Now I need a tissue
Nice way to promote B.S., "Moderator".
Who started it? "Mr Transmission-know-it-all" might be construed as an insult. Against the guidelines.
Originally Posted by SID297
Some guy corrected your spelling and you wanted to take your ball and go home. Try growing a little thicker skin.
Exactly. Mark didn't say anything wrong.
Well put.
If you have a problem with my handling of anything, take it to PMs, or better yet, complain to an Admin.
If you ever have any problem with a moderator, feel free to take it to a higher-up.
Nor should they be.
Hey...all in fun!
Exactly, this was all just some innocent funnin'
**** it, you people suck.
BTW: it was just a misspelling. You **** made it into something bigger so go **** yourselves.
And you launch with insults.
We don't need this here. If you want to insult people, go to Pirate 4x4, or some other trash-talking site where they allow that sort of thing. Oh, that's right, lots of people don't bother going there anymore because they have to wade through piles of BS to find something out.
Geez, if I could do that I wouldn't need a wife.
I don't know man, even if I COULD do that to myself, well, I'd still want a woman to WATCH
And with that being said, when more information comes out I may try to work on retrofitting a 6r140 into a duty. If I could get that to work I could see it becoming very popular, much more so than a Gear Vendors overdrive unit.
Six gears instead of five, plus it's a double overdrive. That should translate into a nice increase in mileage, if the gears are spaced properly, while still being able to run 4.30s.
The double overdrive might work out well for a diesel, but for the V10, I suspect you will need a lot more go-pedal (or at least, the servo-operated throttle body will have to open more) which will probably ruin any gas mileage increase.
Meaning, say you're running at 1200RPMs at highway speeds. That will probably be too low in RPMs for any decent efficiency.
With 4.30s I suspect highway speeds would be around 1800-1900 rpm at about 70mph. That should put very little additional load on the engine. Think of it as the mileage difference between 3.73s and 4.30s.
I just am not seeing the advantage to double overdrive for the V10 or any of the gassers for that matter. When towing heavy especially in the hills a fairly low first gear and then 4 fairly close ratios up to 1:1 will work great. The closer you can keep the V10 to its sweet spot the better. A dual OD may be good for the diesel but not the V10 or other gassers. At the base of a hill I'm out of OD and into 3rd (1:1) and sometimes 2nd so OD is useless then. I don't buy trucks for mpg and don't expect it to get good mpg. Too many people buying big trucks and using them as mall crawlers and want good mpg.
You'll be able to run in OD at 1800-1900rpm when empty with the V10 but thats about it. The trans will hunt when loaded and even unloaded when a hill comes up. To run that low of an rpm at 70 you need the low rpm, high torque of a diesel. I run 2000rpm at 70mph and I can pull a decent hill with my truck in OD unloaded but when loaded forget about OD for hills it don't work good.
Depends what the 2nd OD ratio is. To get the rpm at 70mph your talking about, the OD would be super steep with 4.30s.(Sort of like the Toyota Tundras setup) The 3V doesn't have that much more torque than the 2V PI and both prefer the same rpm ranges.
