Modular V10 (6.8l)
Torqshift swap..... DO-ABLE!
Old Mar 30, 2009 | 08:25 PM
  #31
SID297's Avatar
SID297
My point exactly. If those slightly weaker engines can hold OD with 3.73s the 3v should have no trouble doing so in the same rpm range.
Old Apr 2, 2009 | 08:19 AM
  #32
69cj's Avatar
69cj
Originally Posted by Sooper-Doodie;7325366[COLOR=red
]**** it[/COLOR], you people suck.
BTW: it was just a misspelling. You **** made it into something bigger so go **** yourselves.
Whoops, 2 more mispells. Think he needs a Websters or spell check??
Old Apr 2, 2009 | 01:51 PM
  #33
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by dkf
Depends what the 2nd OD ratio is.
Exactly. The whole discussion is kinda pointless until ALL the ratios are known. FWIW, my motorcycle has two overdrive ratios. 4th & 5th, .96 .74 respectively. It's gas powered.
Old Apr 2, 2009 | 03:40 PM
  #34
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, with a 5:1 (or even lower) final drive ratio
Old Apr 12, 2009 | 10:23 AM
  #35
kountzecobra's Avatar
kountzecobra
So, has this swap ever been done? Aside from the electrical differences, what are the physical differences? Linkage and steering column different?
I have a 2000 V10 Excursion and am thinking about a Cummins engine swap using the Torqueshift trans.
Old Apr 17, 2009 | 07:01 PM
  #36
kountzecobra
Anyone have any idea?
Old Apr 19, 2009 | 10:36 AM
  #37
Spike Engineering's Avatar
Spike Engineering
Contact "5.9Excursion" at dieseltruckresource.com. Besides, that web site works better than this one. And, there's more tech. See this thread. The electronics that he deals with doesn't start until 9 or 10 pages into the thread.
Old Apr 19, 2009 | 02:50 PM
  #38
krewat's Avatar
krewat
Yeah, OK It's real name is "Dodge Diesel - Diesel Truck Resource - Cummins"
Old Apr 19, 2009 | 03:37 PM
  #39
Spike Engineering
Yeah, OK Big deal. He asked a question about a cummings swap into an Excursion and I provided a link. And, the guy who did the swap in the referenced thread is an Electronics Engineer who figured out everything on his own.
Would it have been better if I didn't provide possibly helpful information?
Old Apr 19, 2009 | 04:05 PM
  #40
cbradford's Avatar
cbradford
All I can say is WOW this Thread is like one I never seen here before, but I don't go looking
Old Apr 19, 2009 | 04:57 PM
  #41
krewat's Avatar
krewat
This is helpful? "Besides, that web site works better than this one. And, there's more tech."
Tech on what? Cummins' that never came in a Ford? Or Dodges?
Old Apr 19, 2009 | 05:02 PM
  #42
dkf's Avatar
dkf
That same guy has a thread here on FTE also. Its in one of the other sections of FTE. The thread is like 50+ pages long.
Old Apr 19, 2009 | 07:43 PM
  #43
Spike Engineering
The only problem is that most everytime I visit FTE, I get "server too busy" or "Error, the file you have requested can't be found." So, if there is tech, doing a search would take too long because of the server errors.
So, I don't bother with this site often. That's just an observation, so don't shoot the messenger. Heck, I had 4 server errors or "blank pages" just trying to post this reply.
If someone else wants to post a link to the the same thread on FTE, then post it.
Old Apr 19, 2009 | 10:09 PM
  #44
krewat's Avatar
krewat
I'm on this thing all day, EVERY day. I never get errors or blank pages.
I suggest you either open a service ticket, OR - something is wrong with your PC.
Old Apr 20, 2009 | 01:04 AM
  #45
Spike Engineering
Hopefully, you earn money being on here so often.
I have the same problems on three different computers (all three running different OS's), and each one has the same problems no matter where I'm connected in the world. Also, it's the only forum that has the same consistent problems. Don't take this wrong, but not visiting it much is the easiest solution. Yet, every now and then, I check on stuff or post an answer. And the problems are consistent but just on this site.
