longtubes and 5 speed?
Old Mar 25, 2009 | 09:36 PM
paintslinga2010's Avatar
paintslinga2010
Im looking to put some longtube headers on my truck but the ones im looking at say they will only fit automatics with column shifters. Whats the deal? Why wouldnt they fit with a zf?
Old Mar 26, 2009 | 06:42 PM
paintslinga2010
anyone? Ive looked at pictures of automatics with longtubes and i dodnt see that much different between mine.
also how did you guys hook up the egr and oxygen sensor?
Old Mar 26, 2009 | 06:51 PM
Conanski's Avatar
Conanski
The clutch linkage may get in the way. Fittings for the EGR and oxy sensor will have to be added, don't know of any longtubes that have these built in.
Old Mar 26, 2009 | 08:46 PM
Blue Rebel's Avatar
Blue Rebel
VVVV 89 F250 351W ZF 5speed 4x4, and Hooker competition LT headers VVVV
Old Mar 26, 2009 | 08:51 PM
Blue Rebel's Avatar
Blue Rebel
Heres some pics:
Only problem i had was that my motor mounts were junk, and had the engine sitting so low, the headers were hitting the frame and driveshaft. Got new motormounts, and everything fits up perfectly.
Old Mar 26, 2009 | 09:40 PM
paintslinga2010
ok cool, that gives me another option. So no problems with clearance Blue Rebel?
I have found some header reducers with o2 sensor bungs in them, hopefully those will work for my setup.
Im still wondering where on the header to put a bung for the egr. Anyone have some pictures or a good description?
Old Mar 26, 2009 | 09:46 PM
Blue Rebel's Avatar
Blue Rebel
they hit the frame and driveshaft initially, but that was because my motor mounts were gone, the engine was sitting WAY low and to the left. put new mounts in and all fits good now.
Old Mar 26, 2009 | 10:40 PM
Conanski's Avatar
Conanski
Temporarally mount the passenger side header with a couple bolts and mark a spot on the front tube for the EGR fitting. I used a 5.0 tube on the old headers I had simply because I didn't have a 5.8 tube, and in that case it fit nicely on top of the second tube...
Old Mar 26, 2009 | 10:45 PM
DasCheckers's Avatar
DasCheckers
My headers dump in a weird spot but I'm just going to flex tube around to where I need to go.
As for 02 bungs, just weld one into the collector, that's the best place for them.
They are available here: RJM Injection Tech Fuel Injection Parts compatible with 89-93 Mustang 5.0L Mass Air EFI engines
Do you mean where do you need to route the smog tube to that usually goes into the exhaust?
78bigunns
Oct 23, 2007 11:49 AM
oneofakind97
Jun 14, 2007 08:33 PM
CarbedNotch
May 15, 2007 03:57 PM
MattTheCLGuy
Feb 21, 2006 04:08 AM
MattTheCLGuy
Modular V8 (4.6L, 5.4L)
Feb 18, 2006 12:41 PM
