So you have,
53 - TP circuit above maximum voltage.
and
98 - Hard fault present.
Hard fault means the sensor is currently out of range.
A memory code means it was out of range at one time.
The code 53 indicates the TP sensor is exceeding the maximum expected voltage.
If this code is received during the KOEO test, disconnect the harness connector from the TP sensor.
If the code 63 is generated, replace the TP sensor.
If the code 53 returns, repair the short to voltage in the TP sensor wire.
