In addition to the orings, there is a gasket that can be re-used, if in good condition (probably no reason why it shouldn't be in good condition).
EGR O-ring kit number is 3C3Z-9P455-AB or International # 1840778C92; EGR bolts are torqued to 13 Nm
Also - regarding the cleaning fluid ....................
At about 1:40 seconds into the Ford video below, they make the recommendation to not use brake cleaner:
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=436 border=0 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-LEFT-COLOR: #d4d0c8; BORDER-BOTTOM-COLOR: #d4d0c8; WIDTH: 327pt; BORDER-TOP-COLOR: #d4d0c8; HEIGHT: 25.5pt; BACKGROUND-COLOR: yellow; BORDER-RIGHT-COLOR: #d4d0c8" width=436 height=34>mms://multimedia.ford.com/seopts/Tech_31_250k.wmv</TD></TR></TBODY></TABLE>
why does my EGR valve appear to have to bolts holding it in place? Am I looking in the correct place? it is towards the front of the engine on the top?
It's right behind the elbow on the intake. Should have two bolts holding it in place.
