Clunk When Shifting/Engaging Clutch
Old Mar 24, 2009 | 11:11 PM
RangerSteve's Avatar
RangerSteve
Specs: 2002 Ford Ranger 2.3L 5-speed X-Cab, 116k miles
History: Clutch and Throwout Bearing replaced August '08. Clutch engaged roughly when starting out in first and reverse, and sometimes in second if at slower speed. Transmission also a bit noisier than before. Clutch problem has resolved itself, but noise is still present.
Current problem: there is a *clunk* when I release the clutch and the transmission engages the driveshaft -- in almost any gear.
I can actually turn the driveshaft by hand. Just a little bit (0.25" if measuring on the shaft itself), but I've been assured I shouldn't be able to do this. The entire shaft from its exit at the transmission to its entry at the rear end turns. My dad used a "shop stethoscope" to listen to the rear end (fine), u-joints (they're fine) and the tail end of the transmission. The clunk is definitely in there.
What might this be?
Thanks in advance.
Steve
M_Jennings
Feb 8, 2015 10:10 PM
mustys06
2004 - 2008 F150
May 28, 2011 12:53 PM
rquinlans
Apr 24, 2011 11:38 PM
kerry2
Jul 27, 2006 07:02 PM
Rainyone
Bronco II
Nov 5, 2003 07:02 PM
