Oil Leak-Help please
Old Mar 24, 2009 | 03:21 AM
dereknicole's Avatar
dereknicole
First, I know very little about cars. Forgive this elementary question.
My exp is leaking oil. It appears to be coming from a silver metal box with a round plastic piece about the size of a silver dollar. It is directly behind the oil pan.
Any help would be appreciated.
thanks
Old Mar 24, 2009 | 10:37 AM
c_hohensee's Avatar
c_hohensee
That sounds like the bell housing and the plastic plug is the access to the drain plug in the torque converter. What color is the oil that you are seeing?
Old Mar 24, 2009 | 10:41 AM
dereknicole
oil color
the oil is a light to medium brown. It looks about like oil half way through an oil change cycle- if that makes sense.
Old Mar 24, 2009 | 10:46 AM
c_hohensee's Avatar
c_hohensee
Sounds like engine oil as opposed to tranny fluid. Is it coming out of the bell housing area or is possibly coming back from the oil pan or running down from above. What year and engine do you have?
Old Mar 24, 2009 | 10:54 AM
dereknicole
The oil pan appears fine and dry to me. It is a 2003 5.4L 4wd. There is a black bar that the oil is leaking on to and from there it hits the ground.
Old Mar 25, 2009 | 02:15 AM
c_hohensee's Avatar
c_hohensee
I will look under mine today and see if I can give you any more ideas.
Old Mar 31, 2010 | 01:03 AM
joecitizen's Avatar
joecitizen
any updates on problem
c_hohensee, did you ever find out what the issue was? this is an old thread, but my 2003 w/5.4 has started to do the same thing. any info you can provide would be helpful, thx
Old Mar 31, 2010 | 10:55 AM
c_hohensee's Avatar
c_hohensee
I did not have the issue myself, but if it is not running down on the outside of the block it could be a rear main. Otherwise it could be tranny fluid depending on the color, which would be a seal on either torque converter or front input shaft.
Old Mar 31, 2010 | 02:24 PM
Moto Mel's Avatar
Moto Mel
It is most likely the engine rear crankshaft seal or the torque converter seal at the tranmissions front pump. It's a fairly big job for either one so if it's not leaking a lot you might want to just live with it and check the oil levels often in both til you can get to it. I would guess that the cost of repairing either would be more than $500 and only a little more to do both at the same time. Trans fluid can appear to be brown if it's nearing time for a change. How does it smell? If it smells burnt it's probably trans fluid.
thinksnow
May 23, 2013 09:53 PM
Farmboypowerstroke
Nov 20, 2012 10:07 AM
97sonoma
13
Mar 6, 2011 09:31 PM
78fordf-1504WD
Oil & Lubrication
Jul 7, 2005 08:59 PM
Silver Streak
Jun 14, 2002 06:59 PM
