Help me prevent trailer squat
Old Mar 23, 2009 | 09:48 PM
powerstroke72's Avatar
powerstroke72
Got a question for you and alchymist though. Reading only the post and assuming no WD hitch, would you both agree that if he leveled the truck, then hooked up the trailer, the truck would probably be nose high? Just wondering because when he said that about the tongue weight and the truck sitting level when he drops the trailer on it, I assumed no WD hitch. That's a heck of a lot of weight without a WD though.
Old Mar 23, 2009 | 09:54 PM
believer45's Avatar
believer45
Lovely Wife is psychic - she knows EVERYTHING so it is better to fess up and avoid the issues.
Just kidding - been married 31 years, still trying to decide if it's time to come home from the honeymoon. I am a blessed man.
Old Mar 23, 2009 | 09:57 PM
believer45's Avatar
believer45
Yup, without weight distribution if the truck is nose low without and level with the trailer then hooking up squats the back of the truck by whatever the front of the truck is low. If he levels the truck and starts level without the trailer then hooking up will squat the back by whatever the front was low without the leveling kit when not hooked up.
If OP has weight distribution then adjusting the weight distributing hitch can take care if the leveling issue with no investment.
Old Mar 23, 2009 | 10:01 PM
powerstroke72
That's what I thought and if he doesn't have one, he needs one. There's no way I'd be pulling that kind of weight without WD and sway control. The WD should be able to alleviate the squat like you and alchymist said.
As always, great info. on FTE! Thanks b.
Old Mar 23, 2009 | 10:04 PM
powerstroke72
Must have been daydreaming 'cause I missed this. Yeah, I was just kidding. Got a great gal and wouldn't change it for the world. Married 9 years with three kids and life is great.
Old Mar 23, 2009 | 10:25 PM
Headrope's Avatar
Headrope
Yes, I have a weight distributing hitch. Here's the deal ...
As it sits now
The truck is nose down until the trailer is hooked up; once hooked up both the truck and trailer are level.
What I want to do
Leveling kit - raise the front of the truck 2.5" so that is is level with the rear of the truck (w/o a load).
What I suspect
Given that the weight of the trailer lowers the rear of the truck now so that it is level with the stock front height of the truck, it would seem to make sense that the same amount of weight would cause the rear of the truck to squat after installing a leveling kit on the truck.
Bottom line
I want the truck to be level whether or not it has a trailer hooked up to it.
Old Mar 23, 2009 | 10:49 PM
1bddelx's Avatar
1bddelx
Air bags or go up another link or two on the WD hitch. Crank you trailer jack to the ground lifting truck and trailer, then attatch the chains. Trial and error til it's good
Old Mar 23, 2009 | 11:00 PM
canuckelhead's Avatar
canuckelhead
Hey Headrope!
Had exactly the same issues with my 350 and finally went with the airbags. Got the Firestone Ride Rites and installed them last week.
I went from 36 1/2" inches to 39 1/2" at the front, measured from road to underside of fender/wheel well through center of wheel. Still leaves me 2" short to come to the 41 1/2" high rears but very happy with the look.
Installation was a bear as parts did not line up correctly but a full day of thinking and beer got the job done.
Ran about 70 lbs (wouldn't raise much higher and I didn't want them too stiff) air during the test drive and found the ride better. At slow speeds the front end doesn't feel as mushy and soft, you can sense where the wheels are easier. At high speeds the response from dips and expansion joints are not as harsh, you can feel the bags working.
Lowering the pressure to 5 lbs. min lowered the front to within 1/2" of original.
2223 Firestone Ride-Rite Front Air Spring Kit, Air Helper Spring
Sure is nice having the headlight beams up were they should be.
Old Mar 24, 2009 | 01:55 AM
Headrope's Avatar
Headrope
Thanks for the tip on cranking up the hitch another link or two. I'll give it a shot - likely will ad air bags too. Firestone Ride Rites are what I was looking at. They seem to be the 'it' bag.
As for headlights - I had forgotten all about that bonus. I'd written off those things after the night I drove my truck - two years ago. I swear my fog lights are brighter and have more range.
Old Mar 24, 2009 | 01:05 PM
n4aof's Avatar
n4aof
Originally Posted by Headrope
The trailer is a tow trailer and has a 1,300-pound tongue weight (heavy, I know).
What is the gross weight?
Old Mar 24, 2009 | 08:25 PM
grafekie's Avatar
grafekie
Airbags, for sure. Add the auto system to allow you to adjust them on the fly, rather than stopping and hooking up a compressor. There is really no other way to do the job in this case. You can't have two seperate suspension adjustments without an adjustable suspension
Old Mar 24, 2009 | 10:17 PM
Headrope's Avatar
Headrope
The trailer (toy hauler) is roughly 13,000 pounds when fully loaded.
Ruth Oriel
All Things Towing
17
Feb 15, 2018 11:10 PM
D.matthews
Jul 22, 2017 07:59 AM
ithaca1230
Feb 12, 2016 10:20 AM
karynzoo
All Things Towing
Apr 30, 2012 11:08 AM
rlosing
2004 - 2008 F150
Nov 1, 2009 09:54 PM
