Sponsored by: Real Truck
Caliper Selection
Old Mar 20, 2009 | 10:02 PM
Tacohead's Avatar
Tacohead
Caliper Selection
I have a 200 F-250 that the right rear caliper has one of the pistons stuck and I need to replace the caliper. The parts store is showing two options. One caliper that has metal pistons and the other with phenolic pistons. The price difference is about $50. I was wondering what other people are replacing the calipers with and what are they having success with?
Old Mar 21, 2009 | 09:36 AM
Furian's Avatar
Furian
You Keep What You Kill
BUMP for new FTE member!
Old Mar 21, 2009 | 01:47 PM
ReAX's Avatar
ReAX
I suppose the resin piston wouldn't corrode as badly, but if you change your fluid out regularly it shouldn't be a problem. I would stick with the metal, phenolic seems to handle heat well enough as carb spacers, but I am not so sure how well they will hold up with heat and pressure.
Old Mar 22, 2009 | 12:11 AM
Tacohead's Avatar
Tacohead
Thanks for the response. I keep the fluid clean and the truck is well maintained. I ended up going with the phenolic caliper. We will see how it lasts.
Old Mar 22, 2009 | 02:43 AM
Monsta's Avatar
Monsta
Sit. Stay.
I wouldn't think that plastic would corrode at all, ReAX.
From what I understand, Ford Police Interceptors use phenolic pistons in their calipers to help reduce brake fade. The plastic passes less heat to the fluid. I would imagine those cars are subject (at times) to lots of heat and pressure.
Old Mar 22, 2009 | 09:04 AM
DAVE67FD's Avatar
DAVE67FD
Phenolic, Depending on how it is manufactured can withstand very high temperatures and can have a high mechanical strength. Again it depends on how and who manufactures it. If implemented on the brake calipers i would like to think it should be better than the metal ones.
Tacohead, what was the cheaper one?
bigtexan99
Oct 24, 2014 01:14 PM
Neil64
Apr 6, 2010 10:19 AM
superpony18
Nov 8, 2009 12:04 AM
TNTRower
Oct 5, 2006 05:57 AM
MSC
Nov 9, 2004 08:52 PM
