replacement front calipers?
Old Nov 7, 2009 | 08:34 PM
superpony18's Avatar
superpony18
Good evening everyone. Every year since I bought my truck I have to replace at least one front caliper. Every time it has been a siezed piston. Is there any aftermarket offerings for are trucks?
Old Nov 7, 2009 | 08:56 PM
Orezona's Avatar
Orezona
I'm willing to bet this will help you
Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
Old Nov 7, 2009 | 10:03 PM
superpony18
I haven't had any problems with the slide pins, the pistons are siezing in the bores.
Old Nov 7, 2009 | 11:41 PM
pbr man's Avatar
pbr man
How are your rotors and brake pads? Mine seized a piston when my pads and rotors got worn down. The owner of my local Napa said that our calipers have a square cut o ring on the piston and when they travel too far, they will seize and not return the piston.
Old Nov 8, 2009 | 12:04 AM
superpony18
the pads are only 2 months/1500 miles old. I plan on buying powerslot rotors next go around as the stock rotors can't be turned again. The calipers are from napa, wich I have almost never had luck with are local napa store.
simulatedjim
Aug 9, 2014 07:51 PM
Restlesswildman
Jun 18, 2014 07:19 PM
michaelbrainardatwor
Jun 17, 2011 04:11 AM
99StrokeXLT
Feb 25, 2011 04:22 PM
martin8459
15
Jul 23, 2009 03:01 PM
