IM wanting to add a power brake booster to my truck i know ill need the boost and the distribution block but i was hoping some one could tell me what truck i could pull them off of and would it be a good idea to get the coiled brake lines
i think i may have posted and asked this b4 if so i apoligize in advance
I used a 2004 cobra mustand hydro booster I didnt have enough room check my engine compartment out
the hydro booster gives you 10 times the stopping power vacumn booster and it doesnt take up much room if you have a big block with high valve covers you cant get a vacumn booster to fit a lot of go has to have a lot of whoa
Reason: left off some items
u said i can get it off a 2004 mustang cobra right and wat about the distribution block and will the hydrobooster bolt right up or wat
it is real close I think I had to drill 2 holes and make some lines but I didnt change the blocks I got my out of a junk yard 140 bucks you can find info online just type in hydro booster
I will write down everything I had to do to get it in and take some pics if you like
