Well at first i thought that it was my power steering pump going out. I got under the truck and looked and could not find a leak. Well come to find out it is leaking where the resivoir meets with the brake booster. My questions is do i need to change out the whole brake booster i can i just change my resivoir? Please help.
It is leaking from where the brake booster meets with resivoir on the bottom. Can i just buy the resivoir? The parts guys told be that i needed to buy everything together.
If I understand, you are saying the brake fluid reservoir is leaking where it joins the master cylinder. If this is correct you need only buy the master cylinder and not the hydroboost. They are sold separately.
It's doubtfully brake fluid you're leaking if it's the brake booster. Mine was leaking too and it was leaking power steering fluid. I had a mechanic replace it for me. It took about an hour. The metal housing between the firewall and the reservoir needs to be replaced because as far as I know you can't take that apart and replace the seal.
Please someone correct me and educate my if I'm wrong.
Wel guys i think that iam leaking power steering fluid because it is red, so i think i have to change the brake booster. I am going to take to Les Schwab and have it looked at.
Okay, so the brake booster gets power from the the power steering pump and vacuum from the vacuum pump.
Thanks, Nick
All these abbreviations drive me nuts!
