Smaller Disc Brake Booster?
Old Dec 2, 2006 | 03:47 PM
jdbanks's Avatar
jdbanks
So I bought my current truck with MANUAL disc brakes which I found peculiar. Well, after trying to upgrade with a new power brake booster/master cylinder combo I guess I've found the problem.
For some reason, the brake booster won't fit past the valve covers of the engine. I was told it has 428 SCJ heads on it and edelbrock aluminum intake. That combined with the aftermarket valve covers probably are the problem.
Has anyone else run in to the problem?
Is there a smaller disc brake booster/mc setup that I could use?
Do you think changing valve covers would do it or is it the heads themselves?
Anyone have experience with aftermarket brake booster/mc combos?
Old Dec 2, 2006 | 04:03 PM
85e150's Avatar
85e150
How much interference are we talking? If the valve cover was off, would it hit the valve and spring?
Old Dec 2, 2006 | 06:42 PM
jowilker's Avatar
jowilker
Josh, What kind of valve covers are on the engine? Must be tall alum. ones or something. The 428 wont be any larger on the outside than any other FE.
I think 73 and 74 may have run a smaller booster than say 76, like I have.
John
Old Dec 2, 2006 | 09:44 PM
Mil1ion's Avatar
Mil1ion
You have the 11" booster.
The F-350 requires a dual diaphram 9 1/4 " booster
For those of us that put the high valve covers (Ford Racing) on our engines we need the F350 9 1/4 " booster.
F350 4x2 Booster number stamped in pushrod is FT-39
Precision number #2512300
You will also need the F350 MC .
The brake line output is also on the opposite of the MC (fender side) to the one you have.
Old Dec 3, 2006 | 11:01 AM
jdbanks's Avatar
jdbanks
It's not much interference, I'd guess half an inch, but it's hard to tell.
Thanks John, knowing the heads are the same leaves the valve covers or possibly the wrong engine mounts raising the engine higher than it should be. But having looked at those, I don't think they are the problem. They are aftermarket valve covers, I believe aluminum, they have "M/T" on them. I've seen that before, but I'm not familiar with the significance.
Thanks Dennis, I'll have to order one of those. My lines were actually on the fender side. Too bad I bent them to fit the engine side before finding out the booster/mc didn't fit.
jbontke
Jul 18, 2012 08:35 AM
jmf66
Mar 7, 2009 09:59 AM
whitie's
19
Mar 18, 2007 08:50 PM
77f2504by4
Nov 6, 2005 06:47 PM
Jim Larson
Mar 19, 2003 01:45 PM
