Sponsored by: Real Truck
Hard shift from 1st to 2nd
Old Mar 19, 2009 | 02:35 PM
sncblue03's Avatar
sncblue03
2003 F250 5.4L Auto
Every once in a while when im accelerating with a light foot the truck shifts HARD from 1st to 2nd, like slam your head against the back window hard. It doesn't do it when accelerating quicker or to any other gear. Now I've read on here that these transmissions kind of learn your driving, so I got the battery disconnected now to see if I can reset from the P.O.
Any other advice?
Old Mar 19, 2009 | 03:24 PM
dew the thunder's Avatar
dew the thunder
Got an ABS light/Check Engine Light or having any problems with your speedo? When my truck was being brutally harsh on the 1-2 shift I had all those other problems as well. It was the VSS (vehicle speed sensor) in the rear end.
Old Mar 19, 2009 | 05:12 PM
sncblue03's Avatar
sncblue03
No other symptoms. Just hard 1-2 shift.
Old Mar 19, 2009 | 05:33 PM
dew the thunder
Possible it could be a messed up 1-2 accumulator or spring... My Thunderbird use to shift hard enough into second that it would rip the power wire for my amp outta its clip.
Old Mar 19, 2009 | 08:30 PM
senix's Avatar
senix
when mine was doing that, it felt like I was rear-ended. Was a bad TCM.
Old Mar 19, 2009 | 09:06 PM
sncblue03's Avatar
sncblue03
Excuse my ignorance but what is a TCM?
Old Mar 19, 2009 | 09:37 PM
dew the thunder
Transmission Control Module?
Old Mar 20, 2009 | 02:07 AM
senix's Avatar
senix
yup, trans control module
Old Jun 8, 2009 | 04:28 PM
2000sdoodie's Avatar
2000sdoodie
Cool 2000sdoodie pwrstrk shifts hard
My truck shifts fine, no slipping except for when it shifts into overdrive. it shifts a bit hard. no od light flashing fluid is not burnt smelling and is full. any suggestions? where to start? what to look at or try?
alschief
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 24, 2014 04:46 PM
kameronth
2004 - 2008 F150
Dec 12, 2010 12:02 PM
brlird
Sep 1, 2010 02:32 PM
hbonham
Jun 27, 2007 12:13 AM
dfishrmn88
1997 - 2003 F150
Jun 17, 2005 11:23 PM
