Sponsored by: Auxito
Hard 1-2 Shift
Old Jun 17, 2005 | 02:01 PM
dfishrmn88's Avatar
dfishrmn88
Hard 1-2 Shift
I have a '99 F-150 4.6L with 4 speed auto trans. I am experiencing a hard shift between 1st and 2nd gears, most noticable on medium to heavy acceleration. It's hard enough to get rubber when accelerating. It doesn't slip even under heavy loads and is not losing fluid. It is sometimes noticable on the downshift.
Any ideas?
Old Jun 17, 2005 | 02:03 PM
pfogle's Avatar
pfogle
How many miles on the truck? When was the last tranny service? Sounds like a clogged filter.
Old Jun 17, 2005 | 02:19 PM
dfishrmn88's Avatar
dfishrmn88
110,000 miles. Last service about 15,000 mi. ago.
Old Jun 17, 2005 | 02:39 PM
pfogle's Avatar
pfogle
Is the fluid in good shape? GOod color, not odd odors? Is it the right fluid?
Old Jun 17, 2005 | 02:55 PM
dfishrmn88's Avatar
dfishrmn88
Fluid looks ready to change but does'nt smell burnt. Was last changed at a quick lube type place. That is part of what prompted this post. I took it in for service because of the shift problem and the manager tried to sell me a $1200-2500 overhaul (his figures). Another place I called said it could be as simple as a solenoid. Thought I would check your opions first.
Old Jun 17, 2005 | 04:45 PM
l-m tech's Avatar
l-m tech
sounds like you have a broken 1-2 accumulator spring.drop the pan and there is a bore about the size of a siver dollar.remove the retaining ringand the cover the bottom spring is probably broke in 2 .get the uppdated 1-2 accumulator spring and piston,and reassy.good luck
Old Jun 17, 2005 | 11:23 PM
LxMan1's Avatar
LxMan1
I wish mine would bark 2nd gear
KC Excursion
Sep 26, 2016 06:03 AM
KC Excursion
Jul 6, 2016 03:22 PM
LeoJr
May 3, 2012 09:16 PM
fishe1
1997 - 2003 F150
Dec 24, 2010 10:03 PM
sncblue03
Jun 8, 2009 04:28 PM
