1st to 2nd hard shift
Old Dec 10, 2010 | 07:39 PM
kameronth's Avatar
kameronth
About 20% of the time my 06 Mark LT will make a loud "thud" shifting from 1st to 2nd only. You hear it and feel it. It only happens under normal acceleration. I have about 62k on it. When I bought the truck at 38k miles the whole rear end was rebuilt because it was whining around 50mph. It's been whining again but I am not sure if the shift problem is related or not. Just to add about 3 weeks ago while making a hard right turn I heard and felt a huge bang from the rear end. It felt like someone ran into my truck. Again I am not sure if the two are related but any insight would be helpful.
Old Dec 12, 2010 | 12:58 AM
Peter94's Avatar
Peter94
Well, since no one has chimed in yet...
I would say your rear end whine is totally unrelated, and totally annoying (mine does it too).
Your 1-2 harsh can be caused by a few things.
First off you may have a sticking or damaged check ball in your valve body creating the problem.
Another cause could be a damaged or torn piston/servo seal. This would create a hydraulic leak and require your transmission to increase line pressure for that shift.
Or you could have a worn out clutch/band. Your computer detects a slow shift, and will increase line pressure until it sees the shift speed up. When doing this you WILL feel it.
First step is to drain your transmission fluid, and strain it through a coffee filter.
If you find any excessive debris, I would get ready for a teardown...
Old Dec 12, 2010 | 10:27 AM
kameronth's Avatar
kameronth
I appreciate the advice. It is still under warranty so I will explain the rear end and transmission as two different issues. Is the recommended flush every 60k on the transmission?
Old Dec 12, 2010 | 11:55 AM
Peter94's Avatar
Peter94
I cant answer that for sure, as the maintenance intervals I know have changed. I would grab your owners manual and go by that.
How bad is the whine? Generally they say if you can't hear it above #2 blower setting, the dealer wont touch it.
They know its a can of worms too. Rear axle whine is something they will fight and fight and fight...
Old Dec 12, 2010 | 12:02 PM
kameronth's Avatar
kameronth
The whine is much louder in the summer hot months but at the right speed you can hear it pretty well. When I first bought the truck it was really bad and they rebuilt it. I may let it go until it gets loud again next summer.
sg2004
Nov 21, 2014 08:45 AM
MattyJessome
2004 - 2008 F150
Aug 7, 2014 08:09 PM
03prerunner
Jul 8, 2014 08:13 PM
IJRoorda
17
May 9, 2012 08:42 AM
ErrorS
Jan 11, 2011 10:59 AM
