Sponsored by: Real Truck
Delay from stop to start
Old Mar 18, 2009 | 11:17 PM
2001SuperDuty's Avatar
2001SuperDuty
While im sitting at a stop i really notice a pretty big gap. Ill hit the gas then ill feel a thump then ill go. I can notice it while at higher speeds when i let off the gas and hit it again but its not even near as long. also sometimes when the truck goes to shift a bad vibration comes from under my feet and i can also hear it. Its loud then decreases once it shifts. Any suggestions? Thanks Jaret
Old Mar 19, 2009 | 07:24 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Look around for the slip-yoke lube thread. Basically, the slip-yoke on the driveshaft needs to be lubricated.
But with the vibration, that sounds more like u-joints.
Old Mar 19, 2009 | 10:31 AM
bpounds's Avatar
bpounds
Sounds more like a transmission problem, sorry to say. The slip yoke would cause the bump from a stop, but that's about all. Won't cause a delay in acceleration, and won't do anything bad while on the highway. U-joints would cause a vibration, but not the other things.
Old Mar 19, 2009 | 10:43 AM
Primetime1's Avatar
Primetime1
I agree. Sounds like transmission slipping. Check the fluid level 1st - if it is low, fill her up. You could even try replacing tranny filters and fluid as believe it or not I have seen transmissions quit slipping just from doing that if it isn't too far gone.
Old Jun 29, 2009 | 02:21 PM
T8R's Avatar
T8R
I just took delivery of a 99 F250 2wd that is doing the same thing. I only notice it from a dead stop. (The previous owner upgraded the torque converter - so I was wondering if it was related. I'll go check the fluid levels now.) Also headed to check out the slip-yoke lube thread. Thanks.
bthr22
Aug 18, 2013 10:27 AM
IDIDieselJohn
25
Sep 8, 2011 12:08 AM
IDIDieselJohn
Sep 7, 2011 01:11 PM
Robber80
Dec 5, 2007 06:07 PM
scooter_1968
Apr 11, 2003 09:30 AM
