Modular V10 (6.8l)
Knock Sensor
Old Mar 17, 2009 | 09:31 AM
cadman2b's Avatar
cadman2b
Knock Sensor
Where is the duel knock sensor located on a 2005 V10?
Thanks, Bryan
Old Mar 17, 2009 | 03:54 PM
Monster-4's Avatar
Monster-4
According the the Haynes manual I have the 3V knock sensors are located in the same place under the intake manifold as the 2V but it's just has one one each side vs just on one side in the 2V.
Old Mar 17, 2009 | 04:08 PM
mwsF250's Avatar
mwsF250
I confirm what Monster-4 said. Under the intake manifold, one on each side of the "valley" of the cylinder block. There is a boss on either side, with the bolts threaded straight down.The 3V bosses are a little further back, like almost halfway down the length of the block, whereas the single on the 2V is closer to the front. The 3V bosses are slightly higher as well - almost up to the head gasket level.
As an aside, the boss for the 2V single sensor is still cast and tapped in the flat bottom of the 3V block valley, just not used.
If you take the alternator off, you can get a better view into the cave under the intake and see them back there. Mini flashlight and mirror will help!
Old Mar 17, 2009 | 04:16 PM
cadman2b's Avatar
cadman2b
Thanks, that helps alot. The bolts are not there, just a regular metric bolt?
Old Mar 19, 2009 | 06:43 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Hi cadman2b
off topic.... if you have a chance post the link on your project here in the V10 forum..that would be great
Mike
Old Mar 19, 2009 | 02:17 PM
mwsF250's Avatar
mwsF250
Yes, a regular bolt should work. Ford used a flange head with the flange about the same diameter as the sleeve inside the sensor.
rice975.0
Jan 25, 2011 04:21 PM
fords all the way
May 11, 2008 02:43 PM
quisp-n-quake
Feb 5, 2006 04:38 PM
Hanky
Electrical Systems/Wiring
Feb 10, 2001 12:49 PM
fordsrus
Jan 25, 2001 11:00 AM
