Modular V10 (6.8l)
Erratic Idle
Old Mar 19, 2009 | 02:27 PM
Prodbound's Avatar
Prodbound
Erratic Idle
Truck idle's around 900 rpm when warm then jumps up to 1100 for a small period of time then back down to 900. I've cleaned the Mass air flow sensor and the other sensor on the elbow of the air cleaner intake recently but it didn't change anything. Thoughts?
Old Mar 19, 2009 | 05:51 PM
chris60's Avatar
chris60
maybe clean the IAC , next check the TPS ( i think our V-10's have one, my 85 F150 did)
the TPS is like an old radio dial- a rheostat-it gets worn out in the idle position.
Old Mar 19, 2009 | 05:52 PM
Monster-4's Avatar
Monster-4
What year you have? If you have a 2V (99-04) take off your IAC (idle air control) and give it a cleaning. Also maybe replace the gasket. If you still have an issue then look into replacing it. An IAC is not cheap ($60-$75) so try cleaning it first.
If you have a 3V (05+) you won't have an IAC. Maybe some of the 3V guys will have some advise if so.
Old Mar 19, 2009 | 06:45 PM
BareBones's Avatar
BareBones
Need to know the year. My '05 had an idle problem that was cured under warranty when the dealership re-flashed the computer.
Old Mar 20, 2009 | 02:13 PM
Prodbound's Avatar
Prodbound
It's a 99. I'll take a look at the IAC. Thanks
coletr2
Apr 9, 2014 09:04 PM
powerstroker100
77
Mar 3, 2014 06:04 PM
6.9idiatsturbo
Sep 22, 2013 12:09 PM
STEVET1316
Aug 21, 2006 06:58 PM
electricman
Jul 28, 2001 10:01 AM
