Rearend
Old Mar 17, 2009 | 09:23 AM
Ethan9's Avatar
Ethan9
Rearend
I have a 92 f150 4x4 with the 302. Recently it started shaking real bad in any gear between 30-40 mph like they usually do when a universal goes bad. I crawled under and the universals seem solid. Also it makes a noise that sounds like springs when they need grease, but only when im on the gas. Could this possibly be something like a bad pinion bearing? I hope not haha
Old Mar 17, 2009 | 09:49 AM
Conanski's Avatar
Conanski
A tight universal is not necessarally a good one, if one of the caps is dry the bearings will grind and eventually destroy themselves, this could be the noise you hear. The only real way to confirm the condition of the joints is remove the axle and disassemble the joints.
Old Mar 17, 2009 | 10:09 AM
alxsnmr's Avatar
alxsnmr
From the way you describe it, it sounds like a bad U-joint to me as well.
Old Mar 17, 2009 | 10:30 AM
Ethan9's Avatar
Ethan9
Ok thanks I will drop the driveshaft and take apart the joints I always thought if there was no play in the joint then it was ok. Good thing for this forum if it is a joint I almost tore apart my rearend!
Old Mar 17, 2009 | 11:11 AM
95 F150 Dude's Avatar
95 F150 Dude
A bad pinion will usually whine as you travel.
Old Mar 18, 2009 | 11:01 AM
RedWing58's Avatar
RedWing58
yo negro your trucks always breaking man. you need a beastly 300 like mine. haha
Redneckfordf2502002
24
Nov 24, 2012 12:31 AM
morcam123
Apr 24, 2012 07:27 PM
Daviddc114
Aug 26, 2010 05:10 AM
Jitterbug
Jan 31, 2010 08:11 PM
syannuzzi
Aug 28, 2007 08:43 AM
