Front end grind
Old Jan 28, 2010 | 09:37 PM
Jitterbug's Avatar
Jitterbug
Front end grind
Ok guy's, my front end is making a bad grinding noise in 4x4. I really notice it when turning. I changed the fluid and added the slip agent and it isn't getting any better. When the hubs are locked but not in 4 wheel there is only a small vibration like a universal and it turns fine. In 4x4 it almost sounds like a snap from the center of the front end.
Old Jan 28, 2010 | 09:55 PM
Mr. Finch's Avatar
Mr. Finch
Are you driving in 4x4 on solid pavement? If so that is your problem. The front weals have to be able to slip some on turns otherwise it will binde and couse problems.
I get the same thing when plowing, I will put it in 4x4 to climb into a snowy driveway, but as soon as I hit dry pavement with the steering wheel turned it binds up and you hear a poping in the front end.
Old Jan 28, 2010 | 10:04 PM
blakem_85's Avatar
blakem_85
Chances are you have a axle joint or a u-joint getting ready to go. If your hubs are locked in then everything is turning that turns when you are in 4x4, just no power is being applied until you push the magic button (or pull the lever).
Old Jan 30, 2010 | 09:07 PM
Jitterbug's Avatar
Jitterbug
Sounds just like that, but no, it does it even on slippery snow and ice. Something is binding but I don,t want it to break, I know these things happen at the most inopertune times.
Old Jan 30, 2010 | 09:27 PM
jplinville's Avatar
jplinville
Do both axles have the same gear ratio?
Old Jan 31, 2010 | 08:11 PM
Jitterbug's Avatar
Jitterbug
front end grind
yes they are the same, haven't changed a thing since last year
gkharris
6.7L Power Stroke Diesel
40
Sep 5, 2021 09:16 AM
resq302
Aug 21, 2018 10:29 AM
teammaico
2009 - 2014 F150
Feb 12, 2015 02:27 PM
Donald Edmonton
2009 - 2014 F150
May 30, 2014 09:57 PM
