MSD Blaster coil setup
Old Mar 16, 2009 | 06:01 PM
kchaps72's Avatar
kchaps72
Hey I just got a new blaster coil for my truck and it says to install a ballast resistor with it. I've got a DSII with the factory control box, do I need that resistor (I thought they were only for points) and if so how would I wire it in.
Old Mar 17, 2009 | 08:37 AM
kernel-panic's Avatar
kernel-panic
I could have sworn even the DSII setups used a ballast resistor (or was it a fusible link?) - can't remember if it's inline feeding the ignition module or not. Is the coil in question an aftermarket replacement for a points ignition or electronic? The only thing the ballast resistor does is limit input voltage to the coil / ignition - unless the coil you got is sensitive to higher input voltage, it shouldn't be an issue, IMO.
Old Mar 17, 2009 | 10:18 AM
kchaps72's Avatar
kchaps72
Well I've never seen a ballast resistor on it before but since they're so cheap and easy to put in I'll just run one for safety sake. Oh and the coil doesn't specify points or electronic.
Old Mar 17, 2009 | 12:19 PM
91Bronc300's Avatar
91Bronc300
Here's a link that might have some useful info for wiring in the ballast resistor
https://www.ford-trucks.com/forums/3...-question.html
Here's a link about using an HEI module, which limits current internally, instead of the duraspark module. Eliminating the ballast resistor
Dirt cheap Ignition
Old Mar 17, 2009 | 11:22 PM
kchaps72's Avatar
kchaps72
Well I got the new coil and resistor wired in today along with recurving my distributor thnx to Harte3's advice. Felt quiet a nice little extra pep in the throttle and pull in the lower revs. Again thnx for the advice guys.
POPAJON
Jul 17, 2014 04:56 PM
110
Jan 16, 2014 03:29 PM
2tone250
Apr 11, 2012 08:56 PM
FordMan2
Jul 26, 2007 08:07 PM
No Libs
Mar 17, 2004 12:56 PM
