Damn IPR Valve
Old Mar 16, 2009 | 12:57 PM
Welk49's Avatar
Welk49
Angry Damn IPR Valve
So I finally get the chance to change out my HPOP and put in my 17* pump. Got the old one out ready to put the new one in. And the IPR valve will not go in the new pump. The electrical connector on it hits the housing on the new pump. Unsure how they expect you to get the IPR in there. Thought about just grinding the housing down so it will fit , but unsure how thick the housing is and don't want to ruin a good pump. ANy Idead?
Old Mar 16, 2009 | 01:05 PM
MADVAN's Avatar
MADVAN
Remove the solenoid to install the valve.
Bill
Old Mar 16, 2009 | 01:06 PM
BlueMule's Avatar
BlueMule
Put the grinder away. Both pumps use the same IPR so there's no reason it wont fit. Have you tried taking the sheetmetal nut off, removing the magnetic coil and putting the coil back on with the connection facing the other direction?
Old Mar 16, 2009 | 01:08 PM
Welk49's Avatar
Welk49
yeah thanks my stupidity didn't know you had to remove solenoid, got it in. thanks
Zagato78
29
Feb 5, 2017 10:12 PM
dothedew192
Feb 21, 2016 09:58 AM
wackercattle
Nov 9, 2015 09:07 PM
Tugly
Sep 20, 2015 09:00 PM
bigpimpin
Nov 29, 2013 10:12 PM
