what you mean? you think im one of those that turn without blinkers and drive like an idiot? no. i dont drive like an idiot and i ALWAYS use my blinker even if its like 3 in the morning and nobody is near. i just do it out of habit.
See below:
Originally Posted by nflfreak43
...even without it secured i drove around for 3 days with it just sitting there...
ok i understand what you mean but i guess you havent realized just how heavy this box is. its the heaviest sub box i've ever picked up because it has some sound deadener inside it which adds some weight and i struggle to pick it up. but i understand what you mean by i was driving like and idiot because it wasnt secured for 3 days. but i dont understand how you can attempt to attack me by saying that i was an idiot. you could've just simply said you probably should've had it secured but thankfully you didnt have a wreck so just learn from this point on from everyones thoughts you should have it secured. sheesh i've never understood why people can't just do that.
...but i dont understand how you can attempt to attack me by saying that i was an idiot. you could've just simply said you probably should've had it secured but thankfully you didnt have a wreck so just learn from this point on from everyones thoughts you should have it secured. sheesh i've never understood why people can't just do that.
Two people did that.
Originally Posted by ReAX
Secure it down, use your seat belt or straps or even brackets...
Originally Posted by AudioNutz
And don't drive the truck until you do. This is VERY important, your life depends on it.
How secure can you have it mounted for being on a cushioned seat. How do you have it secured? The heavier weight of the box only means it has a higher momentum if you're truck was to face any impact. I can't imagine it if you happened to roll it (not wishing that on you or anyone by any means).
The tint isn't going to hide it. People are going to know its there from hearing it, and some may decide they want to check it out. It wouldn't take much for them to see the box with the amp - everything they need, rip it out and drive away.
There's more to a system install then how it sounds. Just a bit of feedback/support from some people on here. What you go with is up to you, it'll be what makes your truck different.
