Sponsored by: Innova
amp and sub
Old Mar 16, 2009 | 12:38 PM
nflfreak43's Avatar
nflfreak43
amp and sub
im fixing to buy a 12" MTX sub for 50 dollars still brand new in the box. And an 600 Watt amp. i was just wondering where do yall think is the best place for the sub enclosure to sit? i was thinking of making a little box to set right behind my center console and side mount the amp on the box.
Old Mar 16, 2009 | 04:06 PM
ReAX's Avatar
ReAX
If it can be mounted in less than 5" or so, you should be able to mount it behind the seat on a regular cab. You don't say your cab style in the signature, but Flareside should be single cab. Although your picture looks like EC. On an EC, you can build a box to put anywhere.
Old Mar 16, 2009 | 06:19 PM
nflfreak43's Avatar
nflfreak43
yes it is a super cab. i was just wondering where peoples favorite place was to put the sub in there super cab.
Old Mar 23, 2009 | 12:24 PM
nflfreak43's Avatar
nflfreak43
well i went another direction as far as subs go. i got 2 12" Crunch Ground Pounder 500 Watt subs. still got the 600 Watt amp. it'll push them fine the sub box will be sitting on my back seat behind the drivers seat.
Old Mar 23, 2009 | 06:49 PM
rockin300's Avatar
rockin300
id put it on the floor
Old Mar 23, 2009 | 08:46 PM
ReAX's Avatar
ReAX
Secure it down, use your seat belt or straps or even brackets. Looks decent, how does it sound?
Old Mar 24, 2009 | 09:05 AM
nflfreak43's Avatar
nflfreak43
it wont fit. i've already tried it.
and to reax hear it in another truck and it sounded awesome i don't have it hooked up in mine yet i didnt have the money for the wiring kit for it. i should by sunday hopefully.
Old Mar 24, 2009 | 09:55 AM
AudioNutz's Avatar
AudioNutz
And don't drive the truck until you do. This is VERY important, your life depends on it.
Old Mar 24, 2009 | 05:33 PM
nflfreak43's Avatar
nflfreak43
ive got it secured. you just cant see it. even without it secured i drove around for 3 days with it just sitting there no problems and a couple of times i had to slam on the brakes when idiots in front of me turned suddenly with out a blinker. god i hate stupid drivers.
Old Mar 24, 2009 | 07:54 PM
fordboy_52's Avatar
fordboy_52
until you get into a wreck, all it takes is the weight of a bowling ball to kill.
also, i would try to hide your equipment, it looks to me like you are somewhat flaunting it and this can cause someone to want to steal it. just a thought
Old Mar 24, 2009 | 08:05 PM
nflfreak43's Avatar
nflfreak43
yeah true. but to the hiding the equipment. you cant see in the windows in the rear that are tinted because they are so dark. and the fronts im fixing to get them tinted the slightest bit. but i can't hid it anywhere. what bout i dont have enough room do yall not understand. if i could hide it i would. but i dont have enough room.
Old Mar 24, 2009 | 10:04 PM
AudioNutz's Avatar
AudioNutz
Originally Posted by nflfreak43
...even without it secured i drove around for 3 days with it just sitting there no problems and a couple of times i had to slam on the brakes when idiots in front of me turned suddenly with out a blinker. god i hate stupid drivers.
Are you counting yourself?
until you get into a wreck, all it takes is the weight of a bowling ball to kill...
This is what I meant by "killer Bass". A colleague of mine killed his entire family this way in a little fender-bender. (wife, 2 kids) It's bad enough to discover that your stupidity just cost your family their lives, but to then realize that you are going to jail...
Old Mar 25, 2009 | 12:00 AM
displacement4me's Avatar
displacement4me
My 85 spr cab has risers in it, that came from the dealership long ago. I actually have a basic picture of the piece for the back support from when I was dismantling.
Get a hold of these and you have options. This is the route I'll be taking to get it under my rear seat. No generic boxes, and find a slim-depth sub or two. I'd personally opt for that over what you have, but you are going to have to spend more again.
Just an option - depends what's more favorable for you.
Old Mar 25, 2009 | 08:40 AM
rockin300's Avatar
rockin300
so how much will that lift your seat displacement4me,when i had my sub it sat on the floor in between the seat and the dashboard
Old Mar 25, 2009 | 09:43 AM
displacement4me
That's what its had in it longer then I've owned the truck, so thats always been normal for me. That riser is around 4 inches (or so) from what I can remember back taking it apart.
