ARP studs
Old Mar 16, 2009 | 12:29 AM
Randy777's Avatar
Randy777
ARP studs
My truck is almost out of warrenty and I took it in to the dealer for a puking problem that the truck has had since I bought it. They found an oil leak and have taken the cab off to fix it. No word on the puking problem. Should I have them put in the ARP stud kit while the cab is off? I will have to pay for it but since the cab is already off it should be a lot cheaper. Does anyone know about how much it will cost in labor? I heard the ARP studs are about $650.00.
Thanks Randy
Old Mar 16, 2009 | 01:43 AM
powerstroke72's Avatar
powerstroke72
Here's a set for just over $400. Yes, it would be cheaper to have it done while the cab is off but I'm not sure how much the actual labor would be.
eBay Motors: ARP HEAD STUDS FORD 6.0 DIESEL 250-4202 powerstroke (item 310128758875 end time Mar-20-09 13:27:16 PDT)
Old Mar 16, 2009 | 05:28 AM
tex25025's Avatar
tex25025
The average of all the figures that I have seen, seems to be around $1,900 for the labor. However, that figure is for doing the whole operation, since the cab is already off, I don't know, either way you'll be paying for the labor of taking the cab off. If there is anything else that your wanting to do now would be the time to do it.
Old Mar 16, 2009 | 04:59 PM
ruffneck22's Avatar
ruffneck22
i would definately have them put the stud kit in, i got mine for about 500cdn. Also you might want to think about an EGR delete kit. i went with the liberator kit for about 650cdn. Just make sure they torque those studs properly. they have to torque them in the ford pattern walking it up in increments to 280ft/lbs, walk away for a couple hours and hit them again at 280ft/lbs. this is very important as you cant re-torque them without taking the cab off
Old Mar 17, 2009 | 08:09 PM
n6nfg's Avatar
n6nfg
I had the dealer put in the ARP's when my engine was pulled for a bed plate leak. They charged me around $600 for the labor and parts. The new head gaskets were around $400 of this $600, so the labor bill seems to have been around $200.
Old Mar 17, 2009 | 10:03 PM
ruffneck22's Avatar
ruffneck22
what the duece is a bed plate????
Old Mar 17, 2009 | 11:35 PM
bismic's Avatar
bismic
I have a picture of it in one of my albums. It is what your oil pan is connected to. It adds strength and rigidity to the engine.
Old Mar 18, 2009 | 10:31 AM
ruffneck22's Avatar
ruffneck22
so you added this piece? Is it aftermarket or do all of them have it?
Old Mar 18, 2009 | 12:40 PM
cartmanea's Avatar
cartmanea
No, the bedplate is a standard, necessary part of the engine.
Old Mar 18, 2009 | 05:58 PM
mxer0022's Avatar
mxer0022
HOLY WHACK! what kind of head gaskets did they use? were they made of platinum or something? that just seems waaayyyyyy high to me!
Old Mar 19, 2009 | 08:46 AM
JIM_C's Avatar
JIM_C
They are ridiculously expensive. FTE Parts Guy should get them cheaper or a place like powerstrokeshop dot com.
Old Mar 19, 2009 | 08:49 AM
tex25025's Avatar
tex25025
If you go thru the dealership to get them, that is about what they would cost for the set.
Old Mar 19, 2009 | 11:08 AM
cartmanea's Avatar
cartmanea
Isn't that the full kit with headbolts included? I don't think the dealership will sell you just the gaskets.
Old Mar 19, 2009 | 11:30 AM
mxer0022's Avatar
mxer0022
then aftermarket ones have to be cheaper and if that's the case then why would anyone stay with stock gaskets if they have to put the studs in on their own dime?
Old Mar 19, 2009 | 11:32 AM
Kep4's Avatar
Kep4
Jäger
Absolutely!
Make sure they bench test the EGR cooler and engine oil cooler as well.
