got railed!
Old Mar 15, 2009 | 10:04 PM
going slow's Avatar
going slow
got railed!
this weekend was both productive and frustrating all at once...finaly got the garage cleaned out so i can start on the rear frame rails...got everything all tacked in just waiting for my budy to drop of his big welder so i can burn everything in.... ive never done anything this extensive befor, but ive got some friends who build chassis and ive done alot of research up till now..so i went with a basic straight frame with an up over the axle brige... next is 4 link and bags and plumb the lines wire the truck body work....well ive got alot to do !!!
heres the rails... the s10 frame will be cut right behind the cab of the truck and the longer portion of the rails will slide inside the s10 frame and get welded in making a fully boxed frame...
heres a good pic of the s10 frame...just about were the trans output shaft is is were the new rails will start....
ill get more pics as things go along....thanx for the suport!!!
steve-
Old Mar 15, 2009 | 10:47 PM
Julies Cool F1's Avatar
Julies Cool F1
Looks like a fun project! Take lots of picturtes and post them so we can watch the progress!
Old Mar 16, 2009 | 10:24 AM
thepitshop's Avatar
thepitshop
holly c**p that a big drop!! keep us posted! i like this kind of stuff!!
Old Mar 16, 2009 | 10:39 AM
fergusonicford's Avatar
fergusonicford
I'm thinking that you may want to weld maybe 3 or 4 equal length temporary supports across (from one side to the other side) so that warping does not ocurr during welding. thoughts?
Old Mar 16, 2009 | 10:05 PM
going slow's Avatar
going slow
yea ferg. im going to just havnt gotten there yet...ill do that and when i put it in the truck ill do it again with the final cross members...and THEPITSHOP when the rails are on the ground there is just enough room for the bags between the axle and the cross bars that will be welded in ... so when its air'd out it will be on the fenders just the way Ol' Henry whould have wanted it !!!!
going slow
15
Oct 22, 2009 11:08 PM
going slow
19
Mar 24, 2009 08:46 PM
fxstbchopper
35
Dec 1, 2008 10:23 AM
PinkStroker
91
Nov 13, 2008 10:51 AM
Franken-Truck
Virginia Chapter
32
Apr 6, 2007 01:54 PM
