Cruising RPM
Old Mar 15, 2009 | 07:46 PM
HS400's Avatar
HS400
Cruising RPM
What is the limit that you can safely turn these engines consistantly on the highway? I was towing about 8K and cruising at about 2500 rpm @ 67-68mph. Is 2500-2600 rpm going to kill this engine? 1994 7.3. I would absolutly love to have a 6th gear.
Old Mar 15, 2009 | 08:06 PM
David85's Avatar
David85
2500 is no problem at all. For a N/A IDI, its actually close to ideal for those conditions. Bit of a waste for running empty, but for heavy towing its a good speed.
Old Mar 15, 2009 | 08:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
2550 is my normal 70 MPH cruise RPM with no overdrive.
Old Mar 15, 2009 | 09:00 PM
HS400's Avatar
HS400
Well thats great news! Mine is a five speed with a 4.10 gear.
Old Mar 15, 2009 | 09:08 PM
JHoffman93's Avatar
JHoffman93
How do you find out what gear ratio is in these trucks? I have a 5 spd 7.3 and it runs closer to 2800 at 70 empty.
Old Mar 15, 2009 | 09:27 PM
LCAM-01XA's Avatar
LCAM-01XA
Your trans have a top gear ratio of 1:0.76 which means to be at 2800 rpms while moving at 70 mph and rolling on stock size tires you gotta have 4.56 rear gears, I use an online calculator for that stuff.
Old Mar 15, 2009 | 10:02 PM
JHoffman93's Avatar
JHoffman93
Another gear related question, where would I find the transmission model number used in my truck? Is it printed somewhere on the truck?
Old Mar 15, 2009 | 10:40 PM
bad12jr's Avatar
bad12jr
should be a zf5
Old Mar 15, 2009 | 11:09 PM
LCAM-01XA's Avatar
LCAM-01XA
if tis a 5-speed manual, then tis a ZF5, no other models available for those years.
Old Mar 16, 2009 | 10:57 PM
Dave Sponaugle
Could be a 42 or 47 series ZF 5.
The ID plate is on the drivers side in the top 1/3 of the tranny and about even with the shifter for a front to back location.
Probably covered with oil dirt, but take a rag to the flat place about 1.5" tall and 2.5" long.
Transmission number and gear ratios are listed on the plate for all six gears.
What size tires are you running?
1951flatheaddave
19
Feb 9, 2025 03:02 AM
CVokie
13
Jul 27, 2010 10:59 PM
mecambello
28
Jul 18, 2005 10:38 PM
bountyhunter
Sep 30, 2004 11:48 PM
tandlmack
Modular V8 (4.6L, 5.4L)
Oct 7, 2003 06:47 PM
