Squealing pulleys
Old Mar 15, 2009 | 07:19 PM
pgw85706's Avatar
pgw85706
Squealing pulleys
I'm tired of the squealing idler pulley. Seems like every year I put one on just to shut it up. I pull up to the stoplight and it's whirling. And if I hear someone else's screaming, 90% chance it is another Ford. Not sure now even if it is the idler pulley but I'm in the mood to replace both the idler pulley and the tensioner pulley. What is a good brand? I can't find the pulleys on the Motorcraft site and Rockauto.com does not show Motorcraft brand available.
Pat
Old Mar 15, 2009 | 09:14 PM
fordboy_52's Avatar
fordboy_52
i had the same problem with mine. it was a yearly thing to replace them for me as well
Matt
p.s. i tried high price and cheap, both failed around spring time. could be the humidity?
Old Mar 15, 2009 | 09:27 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave
Matt
My '99 does this only on wet days. In the morning I'll start it up and it's whining/screaming like there is no tomorrow. The following day it will be dry and the engine just singings!
It's time to do a serpertine belt anyway. I'm going to see if this makes any difference.
Is there any way of lubricating the tensioner bearing? Perhaps with a dry lubricant that won't bother the belt.
Old Mar 16, 2009 | 06:03 AM
pgw85706's Avatar
pgw85706
Yea, the wet or humid days are the worse. And my belt is in good shape. I've tried WD40 and spray lubricants but that only silences it for about a week. Maybe a dry graphite powder would work better. Bit of relief to know I'm not the only one with the problem.
Old Mar 16, 2009 | 10:36 AM
pawpaw's Avatar
pawpaw
I replaced the "chirping" idler pully on the 94 Taurus 3.8L, about 3 years back, with an all metal one from AutoZone, that had sealed bearings & was well made & also at the best price I could find locally around here.
It's doing just fine & it's build quaity was far & away better than the part plastic/composit OEM one.
For the life of me I can't remember the brand name, but it was a domestic vendor.
So maybe AZ's pully quality & price for a Ranger will be as good.
Old Mar 16, 2009 | 06:55 PM
pgw85706's Avatar
pgw85706
AZ website shows Dayco pulleys.....could that have been the brand?
Old Mar 16, 2009 | 07:53 PM
pawpaw's Avatar
pawpaw
Nope, it wasn't a Dayco idler pully.
I am running Dayco polycog belts on both the Taurus 3.8L & Ranger 4.0L push rod engines though.
They're running just fine, a little quieter than the OEM belts & so far holding up MUCH better.
I'll have to look around & see if I still have the idler pully box. But then the Taurus idler pully vendor may be different than the Rangers.
Anyway AZ's price was way better than anyone else locally, for some reason. around here they're usually higher on most things, so I was surprised when I got the price, & even more surprised when I saw the quality of the part!!!!
Old Mar 16, 2009 | 08:31 PM
herman391's Avatar
herman391
Was it maybe a gates product? I've used them in the past with good results.
Old Mar 16, 2009 | 09:02 PM
wtroger's Avatar
wtroger
I would also check the power steering pump pulley some of these are plastic molded over metal I have seen the plastic loosen up and make some really nasty noises. And they won't do it all the time, the pulley is only about 10 bucks.
Old Mar 17, 2009 | 04:48 AM
pgw85706's Avatar
pgw85706
Hah, never knew to check this one! Thanks. Yes and it is only $10. Dorman seems to be the only brand available for this part on all the websites.
AAP carries only Dayco as well. Rockauto carries also Gates and FourSeasons. They are all about the same price. I'm leaning to try the Gates, I think I used Dayco last replacement.
Old Mar 17, 2009 | 08:45 PM
pgw85706's Avatar
pgw85706
I don't know what it is about the moisture but with the rain the past few days, the pulleys were screaming this morning. Gave me a sense of satisfaction that before I left for the morning I ordered all 3 pulleys (about $40). But as the day went on, the sun came out and driving home all was quiet. Go figure.
Old Mar 17, 2009 | 09:40 PM
pawpaw's Avatar
pawpaw
Yup, I heard them squealing all the way over here in Roanoke, sure will be nice when you get er fixed!!!! lol
I don't know, the Taurus idler pulley bearing had ever so small amount of play/wobble, barely noticeable, but it would chirp sorta like a cricket, drove me nuts for a few weeks until I removed the belt to inspect it & clean all the pulleys & found the idler to be suspect.
Apparently doesn't take much wear to cause one to be noisey.
So remove the belt, give those pullyes a spin to check for bearing roughness & wobble/play, they should be snug, with no side to side play/wobble & roll without noise.
Could be the tensioner spring too, so have you checked the tension range marks on it's casting, to see if the tensioer is holding the belts tension within range????
Old Mar 19, 2009 | 12:03 PM
wtroger's Avatar
wtroger
A lot of times it is the isolation insulation on the tensiner pulley has started to fail and makes a lot of noise when the belts get a little damp they actually slip and then catch causing the tensioner to bounce around more had a bigg ford truck that did this used stehoscope to hunt it out replaced tensioner and noise went away.
Old Mar 25, 2009 | 10:25 PM
aswingerat44's Avatar
aswingerat44
Noisy pulleys?
[QUOTE=wtroger;7270951]I would also check the power steering pump pulley..
I am curious how you trouble shot the noise. I have a 2003 v-6 3.0 liter ranger and have replaced the tensioner,belt and pulley . It is a intermittent
chirp and is in sync with the engine speed. The dealer said the belt got
worn and is slipping ,making the chirp.
If that was the case the new one should not make the noise.
When I had the truck new there was no noise. I took it in at about 70,000 to replace the belt becasue of the noise.
My 1999 xl ranger never made the chirp but it did make a noise when the power steering pump worn out,more of a grinding sound.
It is tough to isolate the sound without the belt on.
Any suggestions?
Old Mar 25, 2009 | 10:51 PM
pawpaw's Avatar
pawpaw
[quote=aswingerat44;7307934]
Any suggestions?
My 94 Taurus has an intermittent "chirp" that turned out to be the idler pulley, with ever so slight "wobble" play in it's bearing.
