Shifts hard
Old Mar 17, 2009 | 03:09 AM
Bertelrud's Avatar
Bertelrud
Thanks. I'll get a manual. Any advice on what manual to look for? I see there's a few different manuals available.
Was the E4OD the only available auto trans back in '96?
Thanks!
Old Mar 17, 2009 | 08:03 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Fleets could still order the C6 automatic in '96. It was the last year for the C6.
Old Mar 17, 2009 | 09:12 AM
Bertelrud's Avatar
Bertelrud
The door sticker says "E". I guess that means E4OD? Did the C6 come with OD? Thanks
Old Mar 17, 2009 | 09:21 AM
MADVAN's Avatar
MADVAN
No.
You have the E4
Bill
Old Mar 17, 2009 | 10:26 AM
Mark Kovalsky
The C6 is a three speed non overdrive, non lockup torque converter transmission.
The "E" code means E4OD.
Old Mar 17, 2009 | 10:48 AM
Bertelrud's Avatar
Bertelrud
Excellent! Trying to find a good manual and start from there. Thanks!
Old Apr 4, 2009 | 06:51 AM
Bertelrud's Avatar
Bertelrud
I haven't got time to look into it until last night. I haven't been running the truck much lately but the harsh shifting seems to come more frequently. Last night I dropped the pan. Oil seems ok. Some slush on the magneto. I then dropped the valve body to check for sticking valves. The 1.-4. valves move smooth and snap back in place when gently pushed with a small screwdriver. So- when I move the EPC valve it seems loose and won't go back without help when pushed all the way out (in direction of center VB). When going the other direction I can see the springs compressing and pushing it out again. But when pushed all the way out it won't return without a little help. It can actually move about 1/8" without being affected by the springs.
Is this correct?
Also when attempting to pull the valve out of VB it won't come out. It only slides out till the inner part of the clip groove needs to go through the outer bore in the VB. It seems like the bore is too small to let the valve go out. Any ideas aroud how to get it out?
All help would be appreciated! Thanks.
Old Apr 5, 2009 | 03:12 AM
Bertelrud's Avatar
Bertelrud
Anyone? I really want to make sure the valve is operating as supposed before I put the VB and pan back on. The fact that it can move about 1/8" without being affected by the spring really puzzles me... Not getting it out adds to that! Thanks
Old Apr 5, 2009 | 06:06 AM
Bertelrud's Avatar
Bertelrud
Ok I got the valve assembly out. It looks ok and slides pretty smooth. No broken springs. The sloop still doesn't seem right... Anyone on her who knows how this valve should act?
Old Apr 5, 2009 | 11:36 AM
beer-30's Avatar
beer-30
My '96 started this yesterday. Today the OD light started fashing. All fluid levels clean and full. On my way to get scanned.
Old Jun 8, 2009 | 11:08 AM
2000sdoodie's Avatar
2000sdoodie
Angry 2000 powerstroke f-250 e4od shifts hard in od
I have a 2000 f-250 4x4 with an e4od and it shifts fine but when it shifts into overdrive it shifts hard. and it seem to shift just a bit early. it goes into overdrive at 40mph. no flashing light. any ideas would be greatly appreciated.
Old Jun 8, 2009 | 02:27 PM
kawa's Avatar
kawa
FYI Only
http://www.amtrans.nl/E4OD-_4R100.pdf
Old Jun 14, 2009 | 09:47 AM
  #28
beer-30's Avatar
beer-30
Hard shifting
I have a 96 350 w/ turbo and microchips tuner. When it started shifting hard, I hooked up the tuner to read codes. It had a shifting error. I cleared the codes and reinstalled performance mode. Everything worked fine. Occasionally it pops up again and I clear the codes out. I'm scheduling a tranny overhaul to eliminate the problem for good. I guess with 280K miles on it, it's time!
Old Jun 14, 2009 | 11:14 AM
  #29
yoslick's Avatar
yoslick
Anybody tried cleaning the speed sensor on the rear axle? Mine was doing the hard shift thingy and cleaning the sensor sure fixed the problem!
Slick
Old Jun 14, 2009 | 12:56 PM
  #30
Bertelrud's Avatar
Bertelrud
I have been fighting a stalling issue for a while. It turned out to be a bare wire under the dash grounding through the u-joint in the steering axle when turning or driving on bumpy roads. Back to the shifting issue: I have not measured the TPS with a volt meter yet but I connected a ohm meter across the two signal pegs on it and measured when slowly moving the pedal. Every time the pedal reaches about 1/4 of total travel the readings disappears for a veeeeeery short amount of time. And sometimes when I let go the pedal really quick it does the same. Can failure in the TPS caus shifting issues like hard shifts or that the trans won't shift from 1. to 2. without going to about 3k? It also shifts to 2. when I let go the pedal fast and kind of play with it. Allissues only happens occasionally.
