Will epoxy hold this..
Old Mar 15, 2009 | 12:46 PM
jamie7375's Avatar
jamie7375
My intake tube on the turbo keepy blowing off where the metal tube meets the short blue vinyl like tube. i got a new clamp but i think my metal tube has been tighten to much and allowing this to slip off...Since that area where the tubes meet, can i use an epoxy to hold the two together and put the clamp on top...i dont see why it would not work but wanted your help before i did it...
Old Mar 15, 2009 | 12:51 PM
Maxium4x4's Avatar
Maxium4x4
You might want to pick up a new hose and replace your old one. Everything has to be free of oil when assembled and a touch of hair spray also works.
Next item, your turbo may be over boosting which blows the boot off the pipe.
Old Mar 15, 2009 | 03:27 PM
cartmanea's Avatar
cartmanea
Clean all the oil off with brake clean or another solvent, then put it back together and torque the clamp to spec, 11 ft-lb. I stopped at 9 ft-lbs because it seemed too tight at that point and I've never had a blowoff. I think most people that tighten them without a torque wrench don't get them tight enough.
Old Mar 15, 2009 | 06:08 PM
Benchwrench's Avatar
Benchwrench
I used contact cement, hairspray was still too slippery.
From the factory it was a solid seal all the way around, I had to really work at prying the tube away from the silicone sleeve.
The best fix is new silicone sleeves.
Old Mar 15, 2009 | 08:09 PM
elee3's Avatar
elee3
What Benchwrench said. Save yourself a lot of trouble and just buy a new one. It's expensive, but having them blow off sucks. I cleaned mine thoroughly and torqued it properly and it still blew off. I finally purchased a new one, and it is a lot more rigid than the old one.
Old Mar 15, 2009 | 08:11 PM
jamie7375's Avatar
jamie7375
do you remember how much it was by chance...and do you have the part number...thanks
Old Mar 15, 2009 | 08:19 PM
elee3's Avatar
elee3
6C3Z-6C640-C
I paid $84 locally, because I was in a jam. FTE Parts guy has it for fifty something.
Old Mar 16, 2009 | 01:58 AM
uscghutch's Avatar
uscghutch
There is new boots that have a red inner liner that are better than the blue stock ones. There is also a bracket that can be purchased that clamps to the pipe and bolts to the alternator. Helps hold it so it can't blow off. I think I saw one once that was around $50. I made one myself out of .32 stainless and it has worked great. I can get a pic up if anyone wants to see it.
Old Mar 16, 2009 | 05:21 AM
jamie7375's Avatar
jamie7375
i have the new boot that is red inside..it seems that the guy who owned this before me tighten it to much. i would like to see the bracket....i put two new clamps on last might so ill cjeck it and see..
Old Mar 16, 2009 | 06:18 AM
bismic's Avatar
bismic
Post it up! I would like to see your handywork!
Old Mar 16, 2009 | 06:36 PM
uscghutch's Avatar
uscghutch
Question
Ok, the pic thing isn't working. Is there a trick to getting them to come up on posts?
Old Mar 16, 2009 | 06:53 PM
bismic's Avatar
bismic
I click on the "user cp" menu item and then click on "pictures and albums". I then add an album. In doing so it asks to upload the pics. Once you do, you can click on the pic you want to post and it will give you the url to copy and paste in your post.
Old Mar 16, 2009 | 09:48 PM
uscghutch's Avatar
uscghutch
Talking Homemade Bracket
caseys
May 28, 2012 09:28 AM
str8sixman
Mar 26, 2011 10:29 PM
Sarpy Creek Bo9y
1997 - 2003 F150
Mar 28, 2009 01:58 PM
badbrad60
Jun 26, 2007 11:30 PM
MAKO314
North Carolina Chapter
Jul 16, 2006 11:10 PM
