just died on me???
Your situation is why I want a code reader (hopefully a DashDaq after tax refunds). Can you get the vehicle read for codes? If so, post them.
Hopefully it is something fairly cheap like plugged fuel filters or even the ICP - and not the FICM. Please keep us informed.
<TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=757 border=0 x:str><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>Wire Chaffing Locations</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.thedieselgarage.com/forums/attachment.php?attachmentid=17301&d=1208412696</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.forddoctorsdts.com/articles/article-05-11.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://fordpowerstrokeforums.com/downloads/Wire%20Chafing%20Locations.pdf</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>FICM and ICP harness recall</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.forddoctorsdts.com/articles/article-05-13.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>mms://multimedia.ford.com/seopts/Tech12_250k.wmv</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://fordpowerstrokeforums.com/downloads/6.0L%20wire%20chafing.pdf</TD></TR></TBODY></TABLE>
If the issue is FICMSYNC, there could be several reasons. Failed cam sensor or wiring, failed crank sensor or wiring, failed FICM module, or crankshaft or camshaft endplay issues causing the trigger wheels to move out of position and away from the sensor.
More likely you have an ICP pressure issue. On an '03 model, the check ball may have fallen out of the bottom of the high pressure pump. This is fairly common and also causes low base oil pressure as the low pressure oil pump in unable to supply sufficient volume because of the large leak caused by the missing check ball in the HP pump, or an o-ring has failed somewhere.
