Exhaust Manifold Question
Old Mar 14, 2009 | 01:04 PM
fmco_muddin's Avatar
fmco_muddin
I am replacing my exhaust gaskets do to a leak, is there any tightening sequence or torque values I need to know?
Old Mar 14, 2009 | 01:19 PM
tjbeggs's Avatar
tjbeggs
Start in the center and work your way to the outside alternating back and forth. And for what its worth its best not to put gaskets in. The best method would be to have the manifold surfaced (ground or machined) flat and reinstall without a gasket. But if you don't have any way to have that done then the gasket should be fine.
Old Mar 14, 2009 | 01:35 PM
fmco_muddin
Ok what's the reasoning behind having it ground?
Old Mar 14, 2009 | 02:17 PM
tjbeggs's Avatar
tjbeggs
It ensures that the manifold is perfectly flat and a nice smooth surface. Rule of thumb I use is that if it comes from the factory with a gasket then use a gasket. if comes with no gasket then no gasket. But I have the luxury to have a head surfaces to machine the manifold at my disposal. Not everyone has that.
Edit: if the manifold was leaking due to a missing or broken bolt then you might be able to get away with just replacing the bolt. Just a lot of work if it still leaks.
Old Mar 14, 2009 | 03:04 PM
fmco_muddin
well my front drive shaft let go and smacked it pretty hard then come the leak so I guess I dont know weather to wait and have manifold ground if I can find a place to do it??? or just put gasket in and be done with it today!!!!!
Old Mar 14, 2009 | 03:46 PM
tjbeggs's Avatar
tjbeggs
Ouch!!! Are you sure its leaking at the flange. I would be concerned of a crack with that happening. You would probably need to find a Engine machine shop or even call a local garage and ask them where they have their heads and manifolds surfaced.
Old Mar 14, 2009 | 03:56 PM
fmco_muddin
ok thanks for your wisdom Tim!!!!
Old Mar 14, 2009 | 05:58 PM
immastrokinnow's Avatar
immastrokinnow
there is a guy selling a pair of exhaust manifolds for like $100 shipped you might want to check that out. the drive shaft could have cracked the manifold.
Old Mar 14, 2009 | 07:20 PM
fmco_muddin
Ok I allready had the gasket so I put it in and took her for a little hot lap and no leaks I will run it till I have time or somthin happens then will get it ground! Now just have to fix 4x4 shifter!!!!
Old Mar 14, 2009 | 07:58 PM
tjbeggs's Avatar
tjbeggs
Run it! Unless it starts to leak just run it!
juni88126
Nov 8, 2010 06:56 AM
jake2582
Jan 1, 2009 04:25 PM
cjben
Exhaust Systems
Sep 2, 2008 10:15 AM
Robber80
Aug 24, 2007 02:33 PM
justin04
1983 - 2012 Ranger & B-Series
May 20, 2004 02:05 PM
