Search screwed up?
Old Mar 14, 2009 | 12:57 PM
matty169's Avatar
matty169
Search screwed up?
How come it doesnt matter what I search for, I get the same results. 17 pages, and none of them having to do with what I searched for. Connecting rod torque specs and bed plate specs is what I need.
Old Mar 14, 2009 | 01:02 PM
texan2004's Avatar
texan2004
Keep the terms as closely realted and specific to what you want to know such that it will not drag in information from other threads not related to the subject. Example. I am having a problem with the compass on my truck where it is stuck in Calibration mode and will not come out. A search for COMPASS CAL pulls up anything mentioning California when they refer to it as Cal. So I dropped the CAL and it paired it down some. I will admit that a Compass only search did pull up threads that never mentioned a compass but did pull up comp and *** referenced in threads.
Old Mar 14, 2009 | 01:05 PM
liv's Avatar
liv
I tried searching for both the above questions without results. The workshop manuals are not working right now, and that is the only source I know that would have them.
I think you would have better luck contacting a ford tech and seeing if he wouldn't mind looking them up for you.
If you don't mind me asking are you building a beefier motor?
Old Mar 14, 2009 | 01:10 PM
matty169's Avatar
matty169
I found the torque specs in the tech pages. No, Im not building a beefier motor, just re-ringing a motor from a 06 to put in a 03.
liv's Avatar
liv
This is from bismics excel file if it helps at all
Torque Specs
Tie Rod End —Inner, castellated nut....................90 Nm
Tie Rod End —Inner, Sleeve Clamp Bolts................55 Nm
Drag link to pitman arm nut.................148 ft-lb
Inner & outer tie-rod end nuts................85 ft-lb
Track bar bracket to frame.....................129 ft-lb
Track bar to track bar bracket bolt............406 ft-lb
Track bar to axle nut................................... 185 ft-lb
Radius arm to axle bolts, and bracket nut.........222 ft-lb
Pinion bearing preload..................................10-20 in-lb
Pinion nut............................................... ..220-280 ft-lb
Ring gear bolts............................................1 20-140 ft-lb
Bearing cap bolts.........................................120-135 ft-lb
Steel Diff cover bolts....................................30-40 ft-lb
Cast aluminum diff cover bolts......................... 24 ft-lb
Wheel lug nuts..........................................120-165 ft-lb
Diff filler plug.............................................1 8 ft-lb
Oil filter cap............................................... ...14 ft-lbs
Engine cover bolts............................................. 15 ft-lb
Fuel return hose.............................................. .....19 ft-lb
Fuel supply hose.............................................. .....37 ft-lb
Injector hold downs....................................24 - 26ft-lb
EGR cooler clamp.......................................53 in/lb
Turbo mounting bolts.................................... 18ft-lb
Turbo pedestal bolts....................................23 ft-lb
Turbo inlet clamp.........................................9 ft-lb
Exhaust manifold.......................................... ...45 ft-lb
Idler pulley mounting bolt..................................... 41 ft-lb
Brakes, disc, front brake caliper pin bolts (2)......................42 ft-lb
Brakes, disc, rear brake caliper pin bolts (2)......................27 ft-lb
Brakes, front disc brake caliper anchor plate bolts (2)...........166 ft-lb
Brakes, rear disc brake caliper anchor plate bolts (2)......128 ft-lb
Brakes, Caliper Bleeder Screw................................13-18 ft-lb
Crossmember Bolts............................................. ....70 Nm
Driveshaft to transfer case bolts..................................111 Nm
Flex Plate Inspection Cover......................................20 Nm
Master Cylinder Outlet Tube Fittings.........................19 ft-lb
Shock Absorber (front)......................................76 ft-lb
Shock Absorber (rear).....................................46 ft-lb
Stabilizer Bar Link Bolts.........................................85 ft-lb
Starter Mounting Bolts......................................22-28 Nm
Thermostat Housing.......................................20-30 Nm
Torque Converter Drain Plug .............................12 Nm
torque converter retaining nuts............................35 Nm
Transfer Case Bolts...........................................31 Nm
Transfer Case, fill/drain plugs...............................27 Nm
Transmission Filler tube bolt..........................10-13 Nm
transmission fluid cooler tubes to cooler bypass valve............27 Nm
Transmission mount-to-cross member nuts...........94 Nm
Transmission, Auto, Drain Plug....................25 Nm
Transmission, Auto, Pan Bolts (20)............11 ft-lb
transmission-to-engine bolts................61 Nm
Water Pump Bolts...........................18 ft-lb
Water Pump Pulley bolts (4)...............18 ft-lb
Wheel Bearing/Hub Assembly Nuts (4).........135 ft-lb
Power steering pressure hose.......................24 ft-lb
Power steering pump mounting nuts......................41 ft-lb
Old Mar 14, 2009 | 01:11 PM
liv's Avatar
liv
Awesome,
Sounds like you have a fun weekend ahead of you. Have fun and good luck.
Old Mar 14, 2009 | 08:39 PM
Maxium4x4's Avatar
Maxium4x4
Up dates across the site have been ongoing, so if you have a question just ask if search doesn't work.
Connecting rod cap and the bolts. Tighten the bolts in the following sequence.
Tighten to 45 Nm (33 lb-ft).
Tighten to 68 Nm (50 lb-ft).
To prevent engine damage, make sure that the longer main cap bolts (M14 x 2 x 127) are installed inboard and the shorter bolts (M14 x 2 x 114) are installed outboard.
Install the lower crankcase. Install all 20 lower crankcase main bearing mounting bolts. Tighten mounting bolts in the following sequence.
Tighten bolts to 149 Nm (110 lb-ft) in numerical sequence.
Tighten bolts again to 176 Nm (130 lb-ft) in numerical sequence.
Tighten bolts to 231 Nm (170 lb-ft) in the numerical sequence.
Old Mar 14, 2009 | 10:32 PM
DFLEX's Avatar
DFLEX
I found out that if you use quotations around the search terms, search works much better
Old Mar 15, 2009 | 03:20 PM
cartmanea's Avatar
cartmanea
Search has been screwed up for a few weeks now. I used to use "+" before each word to find threads containing all those words, now the + does nothing and returns results with any of the words. I've been using quotes lately, but its not as good.
ruh!roh!
16
Jul 17, 2012 03:32 PM
jake00
2004 - 2008 F150
Apr 15, 2012 11:04 PM
azford86
Jul 31, 2007 09:39 AM
RTM
Aug 6, 2004 07:25 PM
ceetwarrior
17
Feb 9, 2004 11:47 PM
