1986 F-250 6.9 Specs
Old Jul 15, 2007 | 08:04 PM
azford86's Avatar
azford86
Well I bought the f-250 and I need to know a few things:
FYI: It is an XLT regular cab with the 6.9 Diesel 4X4.
I would like to know the size of both gas tanks
I would also like to know what axles I have front and rear.
I searched but could not find anything definitive on those two items however I found all the other specs I was looking for.
Thanks in advance
Old Jul 16, 2007 | 03:02 AM
Sycostang67's Avatar
Sycostang67
The gas tanks should be 19 gallons or 16 gallons, or maybe 1 of each.
The axles should be Sterling 10.25 rear, D50 front.
Old Jul 16, 2007 | 03:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks in advance
On the Warranty (VIN) Plate is the AXLE code. It can be decoded using the FTE axle decoder, or post the code here. This code will lead directly to the type of axles used on your truck and the ratios.
Fuel tanks: 19 gallon front & rear.
Old Jul 16, 2007 | 02:13 PM
azford86's Avatar
azford86
This is all I get from my axle code:
C9 3.55 6250 FORD LIMITED SLIP 1987
Old Jul 26, 2007 | 07:37 AM
azford86's Avatar
azford86
Bump for axle confirmation
Old Jul 26, 2007 | 12:51 PM
82F100SWB's Avatar
82F100SWB
Your rear is a 10.25 Ford/Sterling, to ID your front, we need the GAWR off of the door tag. 3850LB is a D44HD, 4600 is a D50
Old Jul 31, 2007 | 09:39 AM
azford86's Avatar
azford86
Thank you for clarifying that. It says 3850 so I have a 10.25 rear and D44HD front.
Thanks again!
VaFordman26
20
Jul 29, 2015 04:09 PM
51M1
Dec 14, 2014 08:42 PM
grey69
Jul 28, 2013 11:07 PM
ahha-retired!
Mar 20, 2011 08:22 AM
poop head
Oct 20, 2004 10:18 PM
