cab squeak? near windshield
Old Mar 13, 2009 | 06:52 PM
89ford73's Avatar
89ford73
i have a funny cab squeak it sounds like its coming from the driver side near the windshield or firewall. it only squeaks when i go down bumpy roads or when my cab twists with the truck on uneven ground, my friend has the same truck and squeak. along with an 89 i had in high school and various other trucks with the same cab style. what is this noise? and when i am going down a rough road and its really acting up, i can push the brake pedal while holding steady speed with my right foot and the squeak will go away instantly. let off brake pedal and comes right back. its definately somewhere in the cab. i noticed that the chrome trim around my windshield is rubbing the paint off where it meets the cowl behind the hood. could this be the cause? how would i fix it?
Old Mar 13, 2009 | 07:29 PM
Eric_F250's Avatar
Eric_F250
i have intermittent squeaks and rattles that i can usually knock out with small shims jammed into offending areas
Old Mar 13, 2009 | 08:16 PM
kawa's Avatar
kawa
Tighten the fender/body bolts. Betcha it stops.
Rog
Old Mar 13, 2009 | 11:47 PM
BlueMule's Avatar
BlueMule
Rog
That'll the 2 that you can see here, just above the filter and to the rear of the hood spring.
Old Mar 14, 2009 | 03:59 AM
ckal704's Avatar
ckal704
Just make the music louder!
Old Mar 14, 2009 | 10:09 AM
travisd's Avatar
travisd
How about wind noise coming from that same general area? It sounds like it's coming from behind the head light switch. I've had the dash off when I was installing gauges and couldn't find a darn thing. It seems when I'm going with the wind it's not as bad or not there at all, but against the wind or 60 miles an hour with no wind and I can hear it pretty bad.
Old Mar 14, 2009 | 03:51 PM
Hussler's Avatar
Hussler
Best guess .. window wing seal
Old Mar 14, 2009 | 06:11 PM
scatgo's Avatar
scatgo
Yea, That worked for me. Tighten the two bolts and your done. Thought for sure it was shocks or some front end promlem.
Yep, thats where my noise is coming from. Small dent where the mirror mounts to the door. Someone clipped the mirror. It messed up the body where it runs along the bottom of the wing window knocking the whole thing out of wack causing air to whistle by. VERY annoying at hi-way speed.
Old Mar 15, 2009 | 12:12 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
well this is the best thread all week you guys fixed my problem as well i thought it was my shocks too what would i do without fte 94-97 psd forum thanks fellas
Old Mar 15, 2009 | 04:28 AM
richdawg's Avatar
richdawg
Mine really looks loose, & a little funky? I'll have to check it out, Good Post.
Old Mar 15, 2009 | 09:15 PM
aaron ford's Avatar
aaron ford
I have the same problem. Fender needs replaced anyway. Anyone got a white pass side?
Aaron
Old Mar 15, 2009 | 09:31 PM
MustangMatt96GT's Avatar
MustangMatt96GT
I tightned it up... and no more noise!!! Great thread, i thought it was my door hinges since my door sags about half an inch...
Old Mar 15, 2009 | 09:51 PM
scatgo's Avatar
scatgo
You can get hinge pins and bushings at NAPA to fix that.
Old Mar 15, 2009 | 10:03 PM
MustangMatt96GT
i have them in my tool box, and i actually did the bottom one and it helped, just need to find a time when i can get somebody to help me align my door afterwards again. First time we ran out of time, i had to go to work, so we aligned the door where it would open and i left for work... i got to fix my door cable too
Old Mar 16, 2009 | 09:27 AM
89ford73's Avatar
89ford73
i am going to tighten up my fenders today and see if it helps. my doors rattle too. i know what that sound is.
PhillyB
22
Oct 2, 2017 03:23 PM
Kemicalburns
Aug 8, 2016 08:30 PM
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
AkF250HD
Aug 7, 2013 06:31 PM
sspears
Aug 19, 2000 12:59 PM
