Fuel pump relay
Old Mar 12, 2009 | 09:31 PM
4X4X4RV's Avatar
4X4X4RV
Fuel pump relay
Anyone know where the fuel pump relay is at on a 03' Ex with 6.0 ?
Its getting a P0278 code and thought I'd start there ........
Old Mar 13, 2009 | 06:11 AM
npccpartsman's Avatar
npccpartsman
P0278 is an injector code which is probably NOT fuel pump related (maybe less than a 1% chance). Sounds more like an injector going south. What are your specific symptoms?
Old Mar 13, 2009 | 06:59 AM
bismic's Avatar
bismic
I noticed on another post that you had alternator problems. Be watchful for signs of a FICM failure. Often times a FICM failure follows electrical problems. With a FICM failure you will get multiple injector codes and sometimes a P0611 code IIRC.
Also, after the alternator problems did you load test your batteries?
Old Mar 13, 2009 | 08:09 PM
4X4X4RV's Avatar
4X4X4RV
Well first I do have the P0278 code but also have a P0232, also involved are two diffrent Ex's.
Mine hade the bad alt. But now I'm working on a friends and it has the codes, I suspect the fuel pump messed up the relay ( found aluminum shaving in the primary filter ) and there is no fuel to the engine, I had the secondary filter cap off while cycling the ignition ...
Old Mar 13, 2009 | 08:40 PM
william_04_x's Avatar
william_04_x
you can check fuse #40(fuel pump) to see if it's blown..i don't believe the FP relay is serviceable..
you can check for for power to the pump by pulling off the plug on the forward end of the HFCM, and chcking for 12v at the harness..
MIKE861943
Sep 12, 2017 08:51 AM
03F350XLT
Apr 8, 2016 05:51 AM
lvin4jc
Nov 12, 2015 04:14 PM
sstouder
Sep 14, 2014 08:14 AM
bondob
Nov 20, 2009 08:24 AM
