Sponsored by: Real Truck
2006 F350 Trans question
Old Mar 12, 2009 | 08:25 PM
chromy's Avatar
chromy
hey guys, i have a question regarding the automatic transmission in my truck. first off it is a 2006 F350, it has a programmer in it, a 4" exhaust, and an air box. (not sure if this info is needed) Anyway, the transmission shifts really mushy from 2nd to 3rd and some time 3rd to 4th. in other words before it shifts form 2nd to 3rd, you can feel the shift out of 2nd, but the RPM revs about 400 rpm higher before it actually goes into 3rd. i hope this isnt too confusing...............any help is greatly appreciated.........
the only reason i ask is because i have very little miles before the warrenty runs out..
Thanks alot
Chris
Old Mar 12, 2009 | 09:44 PM
Furian's Avatar
Furian
You Keep What You Kill
BUMP... new FTE member needs assistance!
Old Mar 12, 2009 | 10:54 PM
powerstroke72's Avatar
powerstroke72
When was the tranny serviced last? How many miles on the truck? I think I'd look toward getting the tranny serviced - full flush. If you've still got warranty, I'd get in the shop and let them check it out. Also, what kind of tuner? Not all of them address the tranny in their programs. If it's revving between gears, I would think there's something slipping somewhere. One of the transmission gurus should be along soon.
Old Mar 12, 2009 | 11:03 PM
Jim McCarty's Avatar
Jim McCarty
What brand of tuner do you have?
I had an Edge Juice w/Attitude installed with 17 miles on the odometer. A little later, the transmission starting slipping between shifts. I removed the tuner and dumped the KAM so I could cheat the dealer and get the tranny fixed on warranty.
I never did take it to the dealer. As soon as I got in it after removing the tuner, it quit slipping. It now has 119,000 trouble free miles.
Old Mar 13, 2009 | 11:33 AM
chromy's Avatar
chromy
its a Preditor program. and the truck has 105,000 KM(not miles). also we took the programmer out during the winter and it was still acting up. the trans has never been flushed as far as i now of. the truck tows a 48 foot enclosed car trailer with 2 race cars. in other words i work this trucks ***** off!! the only concern i have is that it will run OKAY until the warrenty runs up. than the tranny will puke and ill be stuck with a 5000$ trans bill.
Old Mar 13, 2009 | 11:38 AM
spr1516's Avatar
spr1516
go to the dealer an have them reflash the PCM
Old Mar 13, 2009 | 11:44 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You need to get the fluid and external filter changed immediately - you are way past the recommended service interval.
Old Mar 13, 2009 | 11:50 AM
chromy's Avatar
chromy
i have to call the deal and make an appointment......................why get the PCM reflashed?
one thing i do know, is that my programmer when i put it back in the truck, i have to put the truck in tow haul mode, and do 4 tests.
test1 - 1/4 throttle until 90KM
tes 2 - 1/2 throttle until 90KM
test3 - 3/4 throttle until 90KM
tes4 - full throttle until 90KM
Old Mar 13, 2009 | 12:07 PM
Furian's Avatar
Furian
The PCM controls most functions of the engine and transmission. A re-flash will ensure that you have the latest programming and may address the shift issue with your transmission.
gogoat
Jul 13, 2016 08:28 AM
Laneely84
Oct 27, 2015 05:12 PM
bigbuick
1997 - 2003 F150
Nov 21, 2010 08:19 PM
cclc1021
Apr 2, 2009 10:49 AM
Firminator_X
Jul 2, 2008 06:05 PM
