change up pipes?
Old Mar 12, 2009 | 09:51 PM
mueckster's Avatar
mueckster
Of the six uppipe jobs I've worked on, one pipe is usually loose enough to pull out without loosening the flange. Once one is out. The Y manifold (baby's butt/ collector) can be removed with the other pipe attached.
Old Mar 12, 2009 | 09:52 PM
shark1979's Avatar
shark1979
what would it hurt to take a air saw or sawzall to the old ones as long as i did not cut anything elese
Old Mar 12, 2009 | 09:56 PM
mueckster's Avatar
mueckster
Not a problem at all.
Old Mar 12, 2009 | 09:58 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by mueckster
Of the six uppipe jobs I've worked on, one pipe is usually loose enough to pull out without loosening the flange. Once one is out. The Y manifold (baby's butt/ collector) can be removed with the othe pipe attached.
I know what you mean Roland. I used the sawzall on the passenger side of a friends truck and when we pulled out the driver side the piece we left in baby's butt just fell out.
Old Mar 12, 2009 | 10:09 PM
Smokin''s Avatar
Smokin'
Smokin
This mod is where a hole is cut behind the grille that allows better air flow to your air filter. A type of ram air effect.
huh. I have that mod and didn't even realize it...
And how many years have I been lurking around this site...lol
Old Mar 12, 2009 | 10:11 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
You'll want to take the passenger side fender liner out so that when you're tightening things up you have semi-decent access to things.
Old Mar 12, 2009 | 10:20 PM
shark1979's Avatar
shark1979
this sound more fun by the minute. the lift in the truck is not going to make this any enjoyable
psd96
Apr 16, 2013 09:11 PM
freedomfarmer
Jan 3, 2012 11:18 PM
Benchwrench
Sep 16, 2010 01:09 PM
chicagodragon
Feb 26, 2010 11:52 PM
Farmboypowerstroke
May 9, 2009 09:38 AM
