up pipe gaskets
Old Feb 25, 2010 | 08:27 PM
chicagodragon's Avatar
chicagodragon
up pipe gaskets
how much fun are these to change without pulling the tranny? any tips or pointers?
Old Feb 25, 2010 | 08:33 PM
F350-6's Avatar
F350-6
Wear safety glasses when under the truck since there's an awful lot of dirt and stuff that falls on top of you. And get a buddy to help. Long extensions and a swivel joint, several applications of PB blaster before you start, and coat everything in anti-sieze before you put it back together.
Old Feb 25, 2010 | 09:13 PM
oldbird1965's Avatar
oldbird1965
I just pulled my turbo out and I'm changing mine out. With the turbo out of the way its still a hard job. I don't want to sound discouraging but I don't see how a person could do it with the trans and turbo in. What is making mine a little harder is I bought the brass donuts from Beans and they have to be heated up to get them to fit the pipes. I even disconnected the up pipes from the exhaust manifolds to make more wiggle room. Its a bitc!!, good luck.
Old Feb 25, 2010 | 10:02 PM
chicagodragon
i planned on pulling the turbo. the in cab noise from the leak is driving me nuts.
Old Feb 25, 2010 | 10:10 PM
chicagodragon
ive heard that there is no gasket at the manifold, is this true?
Old Feb 26, 2010 | 12:10 AM
oldbird1965
Yes, that is true, no gasket or donut at the maniford.
Old Feb 26, 2010 | 12:19 AM
chicagodragon
so, you pull the turbo,swap the donuts?
Old Feb 26, 2010 | 09:09 AM
oldbird1965
I'm right in the middle of it now, I have to get those brass donuts on the up pipes. Then I'll put the collector back on and go from there. The up pipe removal from the manifolds was easy compared to the collector bolts at the top, they were a bitc! to brake loose. At this point I'm not sure if I should just put the collector on loose, put the pipes on the manifold loose and then put the turbo back on so I have some play in the pipes. If everybody around here would leave me alone so I can get it done I'll give you an update later tonight.
Old Feb 26, 2010 | 09:18 AM
chicagodragon
sounds like my house, wife wont let me get anything done, unless its for her.
Old Feb 26, 2010 | 10:15 PM
oldbird1965
That's for sure. I had a lot of time today but ended up doing those honeydews. When I started out, I heated the brass donuts up a little (this is what Beans said to do) and pushed them on the up pipes and they split. $85 down the drain! I'm not a happy camper because when I called Beans to order the D66, new pedestal and brass donuts they answered the phone on the first ring. I called all day and left messages and no response. I'm pissed, where did you get your normal up pipe gaskets?? I say the hell with the brass ones, the stock ones lasted 168K and were not really leaking but thought sense I have the turbo off I'll replace them. You having any luck?
Old Feb 26, 2010 | 11:45 PM
chicagodragon
havent got started yet (been raining) . i got my gaskets from napa. #17250. number was listed on another thread with all powerstroke part numbers
Old Feb 26, 2010 | 11:50 PM
oldbird1965
How do you like a thread where just two of us are talking, lol? Thanks for that part #, I'll check it out.
Old Feb 26, 2010 | 11:52 PM
chicagodragon
looks like such a crappy subject that no one wants to chime in. i picked up mine today, $2.50 each.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
