Changing #8 Injector Question
Old Mar 15, 2009 | 08:13 AM
megawatt00's Avatar
megawatt00
Originally Posted by F350-6
What did you do to put it in no start? Unplugging the GP's will only disable the glow plugs, but will still allow the truck to start. Besides, if he's only got one valve cover off, if you want to disable the GP's, it would be easier to unhook the GPR.
I don't mind turning the engine over by hand with the injector removed, but don't like the idea of a full compression stroke with the starter if the injector is not in place. I'd hate to think the injector cup would move. I could be wrong on this, but I prefer to just pull the glow plug to be on the safe side.
I'm pretty sure that he used the no start on his DP Tuner Chris.
Old Mar 15, 2009 | 08:28 AM
F350-6's Avatar
F350-6
I see. So now I guess part of the instructions for changing an injector is to install a DP-Tuner first so you have the no start option.
Old Mar 15, 2009 | 08:31 AM
WA.Ranger's Avatar
WA.Ranger
Iknew there had to be an easier way!
Old Mar 15, 2009 | 08:35 AM
megawatt00's Avatar
megawatt00
I'm sure Jody and Diane wouldn't mind that being included in the manuals for changing injectors.
Just another reason to justify getting a DP!!!
Old Mar 15, 2009 | 09:10 AM
Ziggy.'s Avatar
Ziggy.
When we did JD's, we left both uvhc's unplugged, we changed #8 injector and when we turned it over, it was with the injector in and torqued, but with the glowplug out. It went just fine.
Old Mar 15, 2009 | 09:13 AM
megawatt00's Avatar
megawatt00
I assumed that when JD said no start, he had used the DP no start. Thanks for the info Cory.
Old Mar 15, 2009 | 09:21 AM
Ziggy.'s Avatar
Ziggy.
No problem, well he may have had it in no start, he may not have, idk what he had it set on, I do know that when we turned it over the uvhc's were unplugged, so I guess it wouldnt really matter what he had it set on. But all in all it turned out good.
Old Mar 15, 2009 | 09:27 AM
jdecker88's Avatar
jdecker88
Yes I ment no start on the DP tuner I was kinda hurrying to get into bed last night LOL. We were changing all the GPs and UVCH so it was unplugged as well.
