Changing #8 Injector Question
Old Mar 12, 2009 | 05:34 PM
WA.Ranger's Avatar
WA.Ranger
I'm in the middle of changing out my #8 injector and have a couple of questions while the wife stole my parts runner. Are you sucking the oil out of the cylinder via the glow plug hole? If not, I'm assuming that you need to use a piece of rigid plastic tubing to get pasat the injector hole? How do you know when all the oil/fuel is out? It's sure hard to get a good look in there...
Old Mar 12, 2009 | 05:39 PM
23larry24's Avatar
23larry24
When I changed an injector in my engine I left the glow plug out and rolled the engine over. Disabled of course, so as not to start.
Old Mar 12, 2009 | 05:47 PM
ron's power stroke's Avatar
ron's power stroke
suck the oil out of the injector hole..put the new injector in...then pull the GP...
WA.Ranger's Avatar
WA.Ranger
Yeah, that's what I'm thinking but by hand. I just read Diesel Innovations instructions, and that's basicly what they said. Thanks!
Old Mar 12, 2009 | 07:26 PM
F350-6's Avatar
F350-6
I crank it over by hand a couple of times to remove most of the oil, then unplug the CPS & pull the IDM fuse, install the injector, remove the glow plug, and give it a few short cranks with the key to blow most of the remaining oil out.
It will still smoke when you get it all back together and start it up the first time, but it clears up pretty quick.
Old Mar 12, 2009 | 08:30 PM
orng1's Avatar
orng1
Start with shop rags around the base of the injector and blow out what does get in there with compresed air. I use some brake cleaner in there then blow it out some more but people look at me funny when I spray something in there.
Old Mar 12, 2009 | 08:41 PM
PaysonPSD's Avatar
PaysonPSD
I attach my shop vac to this 5 gallon bucket and use one of the attached tubes to vacumm out any fluids I need to. Got the idea here on FTE.
Old Mar 12, 2009 | 08:52 PM
danskool's Avatar
danskool
Go Bills !
That bucket is the bomb.. I am going to get started on that tomorrow !.. I have been just using the shop vac but that has way more possibility...
Old Mar 12, 2009 | 09:05 PM
orng1's Avatar
orng1
That looks pretty good, to bad I don't have a shop vac.
Old Mar 12, 2009 | 09:16 PM
PaysonPSD's Avatar
PaysonPSD
The mess goes in the bucket and not the vac. Just a word of caution, my 4HP vac will collapse the bucket if I don't have the tube I am not using open. The larger tube will fit through the GP and HPOP reservoir hole.
Old Mar 12, 2009 | 09:31 PM
orng1's Avatar
orng1
And I thought I had gotten it good here.
I did the oil change yesterday.
Old Mar 12, 2009 | 10:09 PM
WA.Ranger's Avatar
WA.Ranger
I'll be building myself one of those also!
Well, injector is in and working good. I changed out the AE for an AD. Thanks for the help fellas.
Old Mar 14, 2009 | 06:30 PM
danskool's Avatar
danskool
Go Bills !
Bob.. That is exactly how i did mine. Syringe. Nice pics.. But got a little arm pump pulling that sucker. SO i got rid of the hose and wedged in a piece of 1/4" metal tube. But now i am amost done with my bucket trap.. Cool.
Metal wedged tube syringe
Old Mar 14, 2009 | 10:40 PM
jdecker88's Avatar
jdecker88
Chris when we did mine we unplugged the GPs and put the truck in nostart and cranked here over that would work as well wouldn't it?
Old Mar 15, 2009 | 07:51 AM
F350-6's Avatar
F350-6
What did you do to put it in no start? Unplugging the GP's will only disable the glow plugs, but will still allow the truck to start. Besides, if he's only got one valve cover off, if you want to disable the GP's, it would be easier to unhook the GPR.
I don't mind turning the engine over by hand with the injector removed, but don't like the idea of a full compression stroke with the starter if the injector is not in place. I'd hate to think the injector cup would move. I could be wrong on this, but I prefer to just pull the glow plug to be on the safe side.
