5th wheel towing question
Old Mar 12, 2009 | 12:59 PM
2005Dually's Avatar
2005Dually
Hey guys I have a quick question for ya-
My buddy has an 06 250 sb cc 6.0 4x4 and he is considering a few different 5th wheel toy haulers, none of which ar over 33' and max weight around 16-17000k. The truck is stock height but a 2.5" leveling kit is on the way. My question is are rear air bags an absolute must with this trailer? Thanks in advance.
Old Mar 12, 2009 | 01:29 PM
diesel_dan's Avatar
diesel_dan
The leveling kit will raise the front so it looks "flatter" when empty, but with weight in the bed this isn't needed. Yes I would bag it, and he should realize that weight is over what the truck is rated to tow. If he's looking at that weight of the trailer "dry" he will be very overloaded when he's ready to go camping.
I wouldn't recommend the level kit at all for this application running at or over the edge of the truck's capacity.
Old Mar 12, 2009 | 04:07 PM
2005Dually's Avatar
2005Dually
I just talked to my buddy again and we think the guy at the dealership (trailer dealership) was mistaken on the loaded weight of the trailer. It seemed real high to me but now were coming back with around 10-11k loaded. I am still going to recomend the air bags to him. Thanks for the reply diesel dan.
Old Mar 12, 2009 | 05:09 PM
69cj's Avatar
69cj
My 5er is 11k with a 1500 lb. pin weight. My f-250 sits level when hitched to the 5er. f-250 is 100% stock except for Bilstein shocks. You should have no problem.
Old Mar 12, 2009 | 06:05 PM
ATV Racer's Avatar
ATV Racer
I agree with 69cj. I have a 30' toy hauler, 4 atvs packed in with all my goods. Absolutely no problems. Truck rides level and pulls like a mule. "02 SD 250.
Old Mar 12, 2009 | 07:17 PM
texans's Avatar
texans
I have a 06 that I pull a 38' Fith wheel with. Coming in around 13K+ dry. around 16 or so fully loaded. I needed the air bags to pull it once I got the Rockstars and bigger tires. before I could pull it, it just set really low
Old Mar 12, 2009 | 11:11 PM
bfife's Avatar
bfife
still plays with trucks
Before he buys a trailer he should load his truck with fuel,folks and all the other stuff he plans on traveling with. Then go to the local CAT scale or equivilent and weigh the truck LOADED. subtract that weight from the GCVW rating and that will tell you the maximum LOADED trailer weight you can tow. It will also tell you how much pin weight you can put on the rear axle. Air bags won't increase the weight capacity of your truck, they are just a bandaid giving folks a false sense of security and the ability to overload their brakes and physical limits of axles,tires, wheels etc. know your weights before you buy and make a informed decision. Barney
Old Mar 12, 2009 | 11:41 PM
joe blow's Avatar
joe blow
I have a larger 5th wheel. I have a 6" edge kit all spring with deaver spring packs. I bought firestone kit 2330. I found that the weight from the 5th wheel will squat the truck's rear enough to make my truck sit like a pre runner. Now add fire wood to the mix ( I line the entire bed up to the 5th wheel hitch with wood) it really squats. I ordered the bags and had to make custom spacers that measure 2.5" in heighth. I inflate the bags to 75 psi and the truck levels great and rides spongy but nice. I RECOMMEND THEM.
Worse case.....you'll have 'em if you need 'em. The kit is about 250.00 for the application applying to 5th wheel hitches. The spacers cost me 15.00 in steel (4" schedule 80 pipe and four 4x4x1/4" precut steel plates) and about 3 hours of fabbing mostly to figure the best way to make them.
Old Mar 13, 2009 | 08:05 PM
2005Dually's Avatar
2005Dually
wow, thanks for the posts everyone. Looks like some good suggestions.
budhare
6.7L Power Stroke Diesel
46
Feb 19, 2017 07:58 PM
kenscomet
Jan 12, 2014 08:46 PM
Northbrook
Apr 14, 2011 09:31 PM
lonerangerinaz
Bronco II
Nov 17, 2009 06:07 PM
Fishsimion
All Things Towing
Jun 19, 2006 09:34 PM
