question on vacuum tubes I have a 73 is there a map of the vacuum system anywhere?
My question is shouldn't this choke be attached to the tree? It hasn't been for years dont know why people would pull it but I want to fix it back up now that I own it. Also should I run a line from the vacuum tree to the carb intake (essentially a open vacuum line to the inside of the air filter)
That is the choke stove pipe, it goes to a heat source, which the vacuum drawns heated air thru, which heats the choke cap and spring and opens the choke.
Does your truck still have the manifolds or headers?
cool thanks, is this pipe something I can recreate or make out of copper? I cant find it in LMC and the other end was squished so I would need to re-flange it anyway, which likely makes it too short. I have also read that rubber high-temp pipe works.
