vacuum question on carb hookup
Old Mar 11, 2009 | 09:50 PM
spudgunman's Avatar
spudgunman
rebuilt my carb choke stove pipe but looks like either 1) its not able to pick up enough heat or 2) the thermostat spring isnt working good any more.
for 9 bucks I can fix the carb choke to a manual pull thingy question is before I go to the hardest part of routing a pull cable thru the firewall. Is there anything else easy I can check on the choke -any easy test to see if the spring is working correctly. Or should I just run some more copper pipe - not in the original area as pictured but I figure if I Loop a hunk around the exhaust manifolds ...some heat will get into the air that way.
I did check the other end of the copper pipe for proper vacuum and its jsut fine so there is air moving past the spring. just ...not warm air I guess.
Is there anything else I need to check, should I run extra copper around the exhaust to transfer more heat? Should I just flip it to a pull cable?
Old Mar 11, 2009 | 10:12 PM
Jermafenser's Avatar
Jermafenser
Is the spring rusted? If it looks good, it's most likely functional. Also, test the choke wire. It should show approximately 7 volts with the engine running and the wire connected to the choke thermostat housing.
The choke pulloff needs to be able to hold vacuum. If it doesn't, replace it.
Are you sure you have adjusted the choke correctly?
Old Mar 11, 2009 | 10:43 PM
spudgunman's Avatar
spudgunman
no electric assist to no voltage. the spring is ..old but not rusted. The choke pulloff to hold a vacuum where is that and what is it holding (assume its just a diaphragm)? How would I go about testing that part? I do have a 10bar vacuum on the brass fitting that mean its working correct?
Old Mar 11, 2009 | 10:58 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
How long are you waiting for the choke to open? It takes a moment longer for the heat style choke to open versus an all electric one which opens rather rapidlly.
Josh
Old Mar 11, 2009 | 11:06 PM
spudgunman's Avatar
spudgunman
i drove around about 30 min so she was nice and hot. I didnt notice that it was "open" for idle.
Old Mar 11, 2009 | 11:28 PM
Bullitt390's Avatar
Bullitt390
Hmmm... could be something wrong somewhere.
I just installed the universal kit on my truck. Ran it to cylinder #5 header pipe and set the choke cap to notch "1". Seems to be working fine at the moment. I still have open headers and cannot really run the truck for long, but just idling it in the driveway the choke is operating.
Josh
Old Mar 12, 2009 | 08:00 AM
Jermafenser
What do you mean by "no electric to no voltage"?
The choke pulloff is indeed only a diaphragm. It needs to be able to hold it open with a vacuum source (to pull the choke butterfly to a preset clearance) when starting it.
This thread should answer a lot of questions.
https://www.ford-trucks.com/forums/7...ml#post6422219
Old Mar 12, 2009 | 10:08 PM
spudgunman's Avatar
spudgunman
typo should say No electric assist SO no voltage. yea I have read that thread but as its about carb tuning and not so much the choke issue. I ran a longer tube of copper pipe today around the exhaust headers (more heat more surface area idea) but when I pop the hood after running for 30 min around town the choke is only 3/32 open like when cold. I do need to figure out how to adjust the fast idle index as I think that is off I don't understand this part
5. Now the important part. Look down at the fast idle linkage, underneath the choke cap on the passenger side of the carb. There is a small cam above the throttle shaft. You will see a small V notched onto the second step of the cam, and you will see a long screw with its tip touching the surface of the cam. The tip of this screw must be aligned perfectly with this V. This is the measurement Ford uses to tell you that you've set the fast idle index properly. If it is not aligned with the V, there is a small hex screw on the plastic fast idle arm in the linkage. You turn this to adjust the index. Each time you adjust this screw, you must start this procedure over and check for alignment.
where is that hex bolt - is that "in" the choke thing (take off the black cap and pull out the paper gasket?) would this help with the choke working correctly? so is my choke issue related to the carb tuning? the truck runs fine and only has a very high curb idle which needs fixed. But is that in relation to the choke not opening up when the car is hot?
Old Mar 12, 2009 | 11:01 PM
Jermafenser
What type of choke do you have? The electric-assist or the heater hose? Since you're in WA, it should have the electric assist. Or did the truck came from down south like in the desert? Do you know its DSO?
You're getting it. I didn't get it at first, but after some head-scratching, I finally figured it out. Just spend some time with the instructions and your carburetor, you'll get it. Then you wonder how more simple it could have gotten.
You're correct, it needs to be properly set-up in order to get the whole system working. The choke is a part of a carburetor tuning. It isn't set properly, so that's why you see the choke not opening fully after the engine is toasty.
No, it's not inside the housing. It's that long screw with a hex head underneath the choke housing. Near the opposite end of that screw, you will see a cam. This end of hex-head screw needs to be aligned perfectly with the "V" mark. This is called setting the fast idle. Before you do this, adjust the pulloff clearance first because the fast idle step is the second step.
Old Mar 13, 2009 | 01:18 AM
spudgunman's Avatar
spudgunman
i will check that out in the daylight, thanks. The truck has lived in seattle its whole life (have the orginal paperwork still!)
Old Mar 13, 2009 | 06:51 PM
spudgunman's Avatar
spudgunman
so I cant find this hex nut for the life of me I have looked everywhere anyone mind pointing it out?
Old Mar 13, 2009 | 08:36 PM
Jermafenser
It's not a hex nut. It's a screw.
Old Mar 15, 2009 | 08:50 AM
  #28
spudgunman's Avatar
spudgunman
well that clears things up a bit -haha thanks. I was looking for something that wasnt there.
Old Mar 15, 2009 | 05:26 PM
  #29
73CaliF100's Avatar
73CaliF100
Originally Posted by Bullitt390
universal choke stove kit either Doorman 03840 or 55111
Do you have a link on this kit? Can it be used with headers? If not, does anyone have a solution for running the stove with headers?
Old Mar 15, 2009 | 05:31 PM
  #30
73CaliF100's Avatar
73CaliF100
I found one;
https://www.vichubbard.com/auto-part...ders.html?js=n
