Remote start problem....
Old Mar 11, 2009 | 08:26 AM
Ryan50hrl's Avatar
Ryan50hrl
well....problem not solved...worked fine all day yesterday after i reprogrammed it, and this morning, back to not starting.....any other ideas???
Old Mar 11, 2009 | 04:49 PM
Ryan50hrl's Avatar
Ryan50hrl
Is it possible that the remote batteries were strong enough to activate the system, but not send the key code or something like that.....
Reason i ask is I changed the batteries and now its working....but if theres something wrong and its going to do it again in a week i wanna keep workin on it.....
Old Mar 11, 2009 | 05:09 PM
screwy's Avatar
screwy
Your remote batteries have nothing to do with it, so long as it’s trying to start, if I had to guess I’d say the problem is either your remote start is being flakey, or there is a problem with the lil coil, either it’s not connected well or there is some interference between it and the reader.
Old Mar 11, 2009 | 05:16 PM
Ryan50hrl's Avatar
Ryan50hrl
Hmmmm.....the coils in the same condition its been for a year now.....and is plugged in tight to the module itself....now i'm really confused....
Old Mar 11, 2009 | 05:25 PM
screwy's Avatar
screwy
Have you tried leaving a key in the ignition when it’s acting up and seeing if it will remote start then? If that works you’ve ruled out the truck side of things, which is unlikely to be the problem. Here are the possible sources, bad pats bypass module, bad connection between the bypass module and the remote start brain, remote start brain is failing to send the proper trigger signal to the bypass module (bad brain), interference between the coil and receiver (try to adjust it’s position), bad connection between the coil and bypass module and intermittent power to the bypass module. Of those I’d put my money on a bad bypass module, but that’s just my guess.
Old Mar 12, 2009 | 01:12 PM
Ryan50hrl's Avatar
Ryan50hrl
Originally Posted by screwy
Have you tried leaving a key in the ignition when it’s acting up and seeing if it will remote start then? .
I guess this is going to be my next try.....remote start worked all day yesterday...probably 15 times during the day after i changed the batteries....go out this morning and walla...no start....now the other weird part is i pushed the button again to cancel the remote start...and then again to start and then it did.....so its really hit and miss.....but dang that leathers cold at 2 degrees above 0 today....i gotta figure this thing out....
07fx4150
Modular V8 (4.6L, 5.4L)
Feb 24, 2016 02:09 PM
Tonyplane
6.2L V8
Jul 2, 2014 07:26 AM
SNIPER168308
Oct 1, 2011 06:37 PM
pabear89
Escape & Escape Hybrid
Aug 24, 2011 12:57 PM
