Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
beeping from dashboard
Old Jul 24, 2011 | 03:05 PM
pabear89's Avatar
pabear89
01 Escape V6 auto
Has a beeping sound from dashboard after start up, It beeps 5 times evenly spaced and repeats this sound 5 times.
Ran OBDII and scanned shows no codes running or in memory.
Sitting in seat, key on ALL lights are on in dash cluster like normal.
Start engine and lights go out, 5 seconds later you hear it beep 5 times and will repeat those 5 beeps 5 times and then nothing.
Runs fine and its not the normal bell tone sounds like not having seatbelt fastened.
When it is going thru its beeping, There is no lights flashing in the cluster at all. I watched all of them very closely for any indication of fault.
Anyone have an idea?
Thanks
Old Jul 25, 2011 | 07:54 PM
FireMe's Avatar
FireMe
Are you SURE the airbag light proves out?
From the manual: "If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the instrument cluster to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair."
Old Aug 24, 2011 | 12:57 PM
pabear89's Avatar
pabear89
Fixed... Seems the bulb for the airbag system only worked sometimes.
One time it would light, till hitting a bump then it would go out.
After removing the cluster and bulb checked with ohm meter and shook it.
Replaced bulb and all is well now.
V8SHO
21
Oct 25, 2018 03:45 PM
Canada, eh
2009 - 2014 F150
Dec 8, 2014 10:13 AM
builtfromiron
Apr 23, 2011 12:52 PM
technomon
Jan 2, 2009 08:11 AM
Norm Carter
1978 - 1996 Big Bronco
Apr 26, 2004 11:00 PM
